Re (2): Eraser Problem
Re (2): Eraser Problem peter@easthope.ca 06 Aug 17:00
  Re (2): Eraser Problem Liam R E Quin 06 Aug 19:41
peter@easthope.ca
2019-08-06 17:00:03 UTC (about 6 years ago)
Date: Tue, 06 Aug 2019 03:46:58 +0000
what’s the opacity setting?
Thanks for the reply.
According to the eraser options panel, 100.00.
http://easthope.ca/GIMPeraserOptions2019-08-06.png
Regards, ... P.
https://en.wikibooks.org/wiki/Oberon
Tel: +1 604 670 0140            Bcc: peter at easthope. ca
Liam R E Quin
2019-08-06 19:41:22 UTC (about 6 years ago)
Note:
If the current layer has an alpha channel, and "anti-erase" is not set in tool options, erasing will cause transparency.
If the current layer does not have an alpha channel, erasing is roughly equivalent to painting with th ebackground colour from the toolbox (press "d" to restore the toolbo colours to their defaults).
If the image is in Index mode rather than in RGB or greyscale mode (check title bar, or Image->Mode) or if anti-erase is set in Tool Options for the erasor, the tool behaves differently.
Regards, ... P.
List address: gimp-user-list@gnome.org List membership:
https://mail.gnome.org/mailman/listinfo/gimp-user-list List archives: https://mail.gnome.org/archives/gimp-user-list
