Putting a GIF on top another GIF
        It sounds like you're getting some of the same problems I've had. With
Gimp-gifs, each layer is a frame. The white frames are probably white
full-screen layers.
What I do is just "take a picture" of the frame that I want (front, middle,
and back in the correct positions) by pressing Ctrl+Shift+V. That copies
the visible. Then I put all the frames I want in order--frame 1=layer 1,
frame 2=layer 2. It's tedious, and there are probably better solutions, but
that's mine.
(I made these gifs with it, so it is doable
http://fc02.deviantart.net/fs71/f/2011/209/7/9/link_by_animatrix1490-d41yjld.gif
http://fc03.deviantart.net/fs71/f/2011/345/5/c/sonic_running_like_an_idiot_by_animatrix1490-d4iug10.gif
On Fri, Aug 23, 2013 at 7:30 PM, Joseph A. Nagy, Jr
wrote:
On 08/23/13 14:39, christopher.draper93 wrote:
I'm trying to combine 3 GIFs with one on top, one in the middle, and one
on
the bottom. When I played the GIF it showed the top one move and a white
space where the other two should be then the top one froze then went onto
the middle one then that one froze and went to the bottom one then
repeated
the cycle. If you want to see what I am talking about let me know.
______________________________**_________________
gimp-user-list mailing list
List address:    gimp-user-list@gnome.org
List membership: https://mail.gnome.org/**mailman/listinfo/gimp-user-**
list
I'm not sure what the initial problem was, but it sounds as if you made an
animated GIF (with a long delay between frames)?
Yours in Christ,
Joseph A Nagy Jr
"Whoever loves instruction loves knowledge, But he who hates correction
is stupid." -- Proverbs 12:1
Emails are not formal business letters, whatever businesses may want.
Original content CopyFree (F) under the OWL http://copyfree.org/licenses/*
*owl/license.txt
list
