how to change stepsize for stroke path with pencil?
how to change stepsize for stroke path with pencil? Santi M.H. 27 Dec 07:56
  how to change stepsize for stroke path with pencil? Ofnuts 27 Dec 15:13
   how to change stepsize for stroke path with pencil? Santi M.H. 27 Dec 16:22
Santi M.H.
2012-12-27 07:56:02 UTC (almost 13 years ago)
I'm using gimp 2.8.2 on debian wheezy and have a little problem, which can be reproduced like this:
File -> New (image size 640x400) Ellipse selection tool 60/60 500x280 select -> to path
select -> none
Pencil tool settings:
mode: normal
opacity: 100.0
Brush: 2. Block 01
aspect ratio: 20
angle: -45
Edit -> Stroke Path (stroke with a paint tool -> Pencil)
At the top and bottom of the ellipse the outline is discontinued.
With View -> Zoom: 800% the stepsize for the applied pencil can be counted. I count a gap of 8 pixels, but I found no way to configure the stepsize. I'd like to have the pencil applied each pixel along the path. Is there a way to achieve this?
cheers
Santi
2012-12-27 15:13:39 UTC (almost 13 years ago)
select -> none
mode: normal
opacity: 100.0
Brush: 2. Block 01
aspect ratio: 20
angle: -45
This is the "spacing" of the brush. Open the Brushes list: click on the brush icon in the Tool options, then on the brush icon at the bottom of the list, or Windows/Dockable dialogs/Brushes, the use the "Spacing" slider.
Santi M.H.
2012-12-27 16:22:19 UTC (almost 13 years ago)
... at the top and bottom of the ellipse the outline is discontinued.
Thanks a lot for that hint!
Seems as if the dialog for existing brushes is read-only and I found no way to switch to read/write mode
Great! That way helped me solve it :) Additionally I found a way to add my own brushes. Thanks again!
Cheers Santi
