GIMP 2.6 and Script-Fu
        Greetings.
The Script-Fu plug-in in GIMP 2.4 uses version 1.38 of TinyScheme. There are
about 8 bug fixes to that version of TinyScheme listed in SourceForge. Most of
these fixes have not been applied to the TinyScheme used in Script-Fu.
I would like to apply most, if not all, of these fixes to the TinyScheme used
in GIMP. A couple of the bugs may have already been fixed but differently to
the official version of TinyScheme. One of the bugs fixed in GIMP's TinyScheme
may have a better fix in the official version although this needs to be verified.
The first step would be to create bug reports for each needed plus a tracking
bug. Not all of the outstanding bugs need to be included in TinyScheme. Some
bug fixes could be held off until after post 2.6. The bug fixes can be applied
quickly so there is plenty of time to run any needed tests on the fixes before
2.6 is out.
It would also be nice to see support for radio buttons added to Script-Fu. I
might need to consult on this with someone as I'm not that good at GTK
programming. I almost had it the last time I tried a patch for this but I
didn't get it 100%.
