gimp-print with 2.2.0?
gimp-print with 2.2.0? Jonty 20 Dec 00:16
  gimp-print with 2.2.0? Robert L Krawitz 20 Dec 00:20
  gimp-print with 2.2.0? Cai Qian 20 Dec 00:22
Jonty
2004-12-20 00:16:37 UTC (almost 21 years ago)
Is there a problem using gimp-print 5.0.0 with gimp 2.2, or is this a configure problem?
checking for gimpprint-config... /usr/bin/gimpprint-config checking for GIMP-PRINT - version >= 4.2.0... *** GIMP-PRINT header files (version 5.0.0) do not match *** library (version 4.2.1)
-Joseph
Robert L Krawitz
2004-12-20 00:20:24 UTC (almost 21 years ago)
Date: Mon, 20 Dec 2004 12:16:37 +1300 From: Jonty
The Print plugin distributed with the GIMP is based on the Gimp-Print 4.2 API, since we (Gimp-Print) didn't get to our 5.0 release in time for the GIMP. Therefore, what you should do is compile the GIMP without a Print plugin and then build the Gimp-Print package to get your print plugin.
Cai Qian
2004-12-20 00:22:16 UTC (almost 21 years ago)
header files (libgimpprint1-dev) and run-time library (libgimpprint1) mismatch.
Cai Qian
