Fw: Enhanced tiffset
Fw: Enhanced tiffset Kevin Myers 10 Jan 11:36
Kevin Myers
2003-01-10 11:36:43 UTC (almost 23 years ago)
----- Original Message -----
To:
Cc: "Kevin Myers"
Sent: Friday, January 10, 2003 4:30 AM Subject: Enhanced tiffset
I've just developed an enhanced version of the tiffset tool that is
shipped
with libtiff. This version provides the ability to change the values of many more tags and tag types. The new version is named tiffset2, and both
a
Win 32 executable and the source code is attached.
The primary reason that I developed this was to provide a fast and easy
way
to change the x and y resolution metadata values in TIFF image headers. This allows one to effectively change the physical image dimensions
without
changing the number of pixels, for example. I needed to do this to work around a bug in the GIMP v1.2.4 which seems to affect images greater than about 187.5 feet in any dimension (yes, my images are that long!).
I started from version 1.2 of tiffset, and did a fair amount of re-work to support the additional tags and types. However, it is quite obvious that much more could still be done. Additionally, I am NOT an expert C
developer
by any stretch of the imagination. So, any comments, suggestions, and corrections would be appreciated and well received.
I'm not familiar with using CVS to check modifications in and out, so I haven't made any attempt to upload this new version to any central code repository. Perhaps someone else would consider doing that...?
Meanwhile, I hope this may prove useful to some of you out there. If so, then perhaps this new version could be included with a future release of
the
libtiff tools.
s/KAM
P.S. - This utility uses and requires libtiff, in case that wasn't already obvious.
------------------------ Yahoo! Groups Sponsor ---------------------~--> Turn flat surfaces into speakers with the Soundbug. http://us.click.yahoo.com/QWAVSC/onCFAA/xGHJAA/NhFolB/TM ---------------------------------------------------------------------~->
To Post a message, send it to: gimpwin-dev@eGroups.com To Unsubscribe, send a blank message to: gimpwin-dev-unsubscribe@eGroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
