GIMP 2.10 Unable to read tile data from swap
14 of 14 messages available
GIMP 2.10 Unable to read tile data from swap Partha Bagchi 01 May 20:17
  GIMP 2.10 Unable to read tile data from swap Ell via gimp-developer-list 02 May 06:47
   GIMP 2.10 Unable to read tile data from swap Partha Bagchi 02 May 10:22
    GIMP 2.10 Unable to read tile data from swap Partha Bagchi 02 May 13:16
     GIMP 2.10 Unable to read tile data from swap Ell via gimp-developer-list 02 May 13:59
      GIMP 2.10 Unable to read tile data from swap Partha Bagchi 02 May 14:36
       GIMP 2.10 Unable to read tile data from swap Øyvind Kolås 02 May 18:18
        GIMP 2.10 Unable to read tile data from swap Partha Bagchi 02 May 19:04
         GIMP 2.10 Unable to read tile data from swap Partha Bagchi 02 May 19:40
         GIMP 2.10 Unable to read tile data from swap Ell via gimp-developer-list 02 May 19:49
          GIMP 2.10 Unable to read tile data from swap Partha Bagchi 02 May 19:56
           GIMP 2.10 Unable to read tile data from swap Ell via gimp-developer-list 02 May 19:58
            GIMP 2.10 Unable to read tile data from swap Partha Bagchi 02 May 20:08
             GIMP 2.10 Unable to read tile data from swap Ell via gimp-developer-list 02 May 20:30
Partha Bagchi
2018-05-01 20:17:12 UTC (over 7 years ago)
GIMP 2.10, Windows 64-bit
I seem to be getting the following errors when using some brushes:
"Unable to read tile data from swap: No such file or directory (0/xxx bytes read) --"
twice, followed by
"Unable to read tile data from swap: No error (0/xxx bytes read) --"
etc. followed by "Too many error messages!"
"Messages are redirected to stderr."
Any ideas on what is going wrong here for me?
Thanks, Partha
PS: I was not getting these swap errors for sometime now and suddenly in the final release, they are back again.
2018-05-02 06:47:58 UTC (over 7 years ago)
twice, followed by
Thanks, Partha
How long ago did it start? Does disabling the separate paint thread fixes this? It can be disabled by setting the GIMP_NO_PAINT_THREAD environment variable.
Ell
Partha Bagchi
2018-05-02 10:22:38 UTC (over 7 years ago)
twice, followed by
Thanks, Partha
Ell
Thanks for responding Ell!
It started again after the final release. It was not there in RC1. I didn't know about the env. variable. I'll check it out and let you know.
This may be a affect of the transition from gegl 0.3 to 0.4?
In the past, it was related to complicated images with high resolution and usually setting GEGL_CACHE_SIZE to 2048 or thereabouts fixed it. Now, it does not.
Partha
Partha Bagchi
2018-05-02 13:16:46 UTC (over 7 years ago)
twice, followed by
Thanks, Partha
Ell
Partha
Hi Ell,
I did the following. I set the following environment variables: GEGL_SWAP=C:\Users\partha\AppData\Local\Temp\gegl GIMP_NO_PAINT_THREAD="Y"
It didn't make any difference. Matter of fact, GEGL_SWAP was unused. So, I removed it and reran GIMP. No change.
Thanks, Partha
2018-05-02 13:59:24 UTC (over 7 years ago)
So it only started at some point after RC1, but before 2.10? (days? weeks?) I'm trying of think of things that changed during that time that might have caused this. Did you change something on your end?
Not likely, especially if it already happened before 2.10. The 0.4 switch happened right before the release.
This sounds like you might have ran out of cache and swap space, in which case you'd start getting write errors. These are read errors, which are much more surprising.
Ok, so it's not the separate paint thread. That's a good thing :) What's the rest of your GEGL setup like? Are you using any other environment variables? What's the thread count?
Do you mean that GEGL wasn't using the swap? Can you use the dashboard to see if anything "interesting" is going on while this happens? Is the cache full? Is the swap nearly full? Do the reported cache/swap size limits make sense?
Ell
Partha Bagchi
2018-05-02 14:36:22 UTC (over 7 years ago)
No, I mean that the change was related to the final release 2.10.0 and not before. I had no reports prior to final release.
My changes are cosmetic. For example, I modify ./app/widgets/gimppanedbox.c
// #define INSTRUCTIONS_TEXT _("You can drop dockable dialogs here") #define INSTRUCTIONS_TEXT _("")
I don't modify anything in babl or gegl. My compiler is gcc 7.1
See above. As you say, 0.4 switch was literally before the final release. In fact gimp.pc.in was changed after the release.
You are right. These are read errors.
My GEGL compilation of simply what environment variables? I only have one GEGL variable active now: gpu usage. My configure from the config.log is:
$ ./configure --prefix=/opt/gimp/std --build=x86_64-w64-mingw32
CPPFLAGS=-I/opt/include -I/usr/python/include -I/opt/SuiteSparse/include LIBS=-L/opt/lib -L/usr/python/Lib -L/opt/SuiteSparse/lib --disable-docs --without-libavformat --without-sdl --enable-workshop build_alias=x86_64-w64-mingw32 CC=gcc CFLAGS=-O3 -ffast-math -ftree-vectorize CXX=g++ CXXFLAGS=-std=c++14 -DMS_WIN64 -O3 -ffast-math -ftree-vectorize
PKG_CONFIG_PATH=/opt/lib/pkgconfig:/usr/python/Lib/pkgconfig:/opt/share/pkgconfig:/opt/gimp/libmypaint/lib/pkgconfig:/opt/gimp/std/lib/pkgconfig --no-create --no-recursion
My thread count is 8. I've tried with thread count set to 1 with the same result.
OK. When I start the dashboard, I have the following: Cache:
Occupied: 0 bytes (0%)
Limit: 7.9 GiB
Swap:
Size: 0 bytes (0%)
Limit: 114.7 GiB
CPU (0%)
Opened image (RGB Color 16-bit gamma integer, MelissaRGB 1 layer) 7378x4924 (D800 36MP image)
Duplicate Layer.
Dashboard:
Cache:
Occupied: 751.6 MiB (9%) Limit: 7.9 GiB
Swap (no change)
Start painting on the layer: Cache:
Occupied: 818.7 MiB (10%)
Limit: 7.9 GiB
Swap:
Occupied: 512.0 Kib (0%)
Size: 4.0 MiB (0%)
Limit: 114.7 GiB
CPU (0%)
But, we have: GEGL Message
unable to read tile data from swap: No such file or directory (0/130568 bytes read) --
GEGL Message
GEGL Message
unable to read tile data from swap: No error (0/130568 bytes read) --
Too many error messages etc.
Ell
Thanks,
Partha
Øyvind Kolås
2018-05-02 18:18:33 UTC (over 7 years ago)
GPU usage meaning OpenCL?
GEGL has stopped enabling opencl by defult now, since GEGL-0.3.24 of 2017-11-24 it no longer being enabled by default since it relies on good results from the varying quality different opencl implementations,.. may also have generic race conditions resulting from new code not manifest during regular testing either, so trying without OpenCL enabled.
/pippin
Partha Bagchi
2018-05-02 19:04:01 UTC (over 7 years ago)
I was using the following:
GEGL_USE_OPENCL=gpu;
Is that what you mean?
/pippin
I removed the above environment variable but no change with my 36MP image. The moment I put the brush on the screen, I get the error messages above.
Then I experimented with some more pictures and it seems to be related to the size of the image.
I open a 1 megabyte (MB), and 4MB image and no error. Then I open a 74MB image without error. But when I opened an 300 MB Tiff, I started getting the error.
I repeated the experiment with GEGL_CACHE_SIZE = 2048 with the same result.
For all all images, I first fit to window > duplicate layer > paint on duplicate layer.
Thanks,
Partha
Partha Bagchi
2018-05-02 19:40:53 UTC (over 7 years ago)
one
/pippin
Thanks,
Partha
One additional piece of data that may or may not be relevant. The When I
change the layer to mode something other than normal and change it back, the painting shows up fine.
Here is the before image: https://www.partha.com/downloads/GIMP/Screen-painting-before.jpg and here is the after switching layer modes to something and back to normal: https://www.partha.com/downloads/GIMP/Screen-painting-after.jpg
2018-05-02 19:49:19 UTC (over 7 years ago)
/pippin
My guess is that this is related to the zoom level (being re getting any more errors.
Ell
Partha Bagchi
2018-05-02 19:56:12 UTC (over 7 years ago)
/pippin
You may be right! I changed the zoom level to 51% and didn't see that error. I'll have to experiment some more of course.
For GEGL, I'll git pull and rebuild to see what the effect is.
Note that the actual bug was the swap being used in the first place. I'm still not sure why you're getting read errors, though. Since the swap shouldn't be used anymore (in this particular case) after the above commit, the errors will probably go away, but the issue causing them might still be there. I'd try to set a very low cache size, in order to force the swap to become very active, and see if you're getting any more errors.
I should do this after update gegl and gimp, correct?
Ell
Thanks!
Partha
2018-05-02 19:58:24 UTC (over 7 years ago)
Yep.
Ell
Partha Bagchi
2018-05-02 20:08:31 UTC (over 7 years ago)
Yep.
Ell
Sounds good.
I think your hypothesis that it's related to the zoom level may be correct. I restarted GIMP with no GEGL environment variables. I opened image > duplicated layer. I set the zoom level to 50.1% and I saw the same artifacts. Then I increased the zoom to 50.5% and it went away.
You realize that for large images, it would be unwieldy to be painting at that zoom level?
Thanks again to you and pippin for resolving this.
Partha
PS: Did you see the screenshots I posted?
2018-05-02 20:30:32 UTC (over 7 years ago)
Yep.
Ell
Sounds good.
Partha
I have now. The artifacts are only present in the flat, downscaled version of the image, and not in the layers themselves, so changing a layer's mode, or doing anything else that would cause the entire image to get re-rendered, would make them go away.
-- Ell
