Documenting GIMP 2.6
Documenting GIMP 2.6 Roman Joost 08 Oct 16:55
  Documenting GIMP 2.6 Sven Neumann 09 Oct 21:01
Roman Joost
2008-10-08 16:55:48 UTC (about 17 years ago)
Hi folks,
Ulf and I are still working on the migration scripts and a modified build setup. It will probably take a few more weeks to seriously think about migrating and continue to work using the po/gettext setup.
As long as we're working on this, there is already room for start working on documenting GIMP 2.6. The savest way on doing this would be to not remove/add any tags, but just modifying strings.
Maybe Ulf is confident with the script (I probably would because of his awesome work ;), that you could just continue to work as usual.
Cheers,
2008-10-09 21:01:05 UTC (about 17 years ago)
for your convenience I've made a diff between app/widgets/gimphelp-ids.h in GIMP 2.4 and 2.6. Here's a list of help IDs that changed or were added:
Changed:
gimp-view-zoom-fit-to -> gimp-view-zoom-fill"
gimp-layer-desaturate -> gimp-tool-desaturate"
Added:
gimp-edit-paste-as-new-layer gimp-layer-new-from-visible
gimp-dock-tab-lock
gimp-windows-show-dock
gimp-windows-open-recent-dock
gimp-config-use-gegl
