GIMP template and tutorial for designing business card
7 of 7 messages available
GIMP template and tutorial for designing business card satimis 10 May 02:15
  GIMP template and tutorial for designing business card Akkana Peck 10 May 18:42
   GIMP template and tutorial for designing business card satimis 12 May 19:25
    GIMP template and tutorial for designing business card Chris Mohler 12 May 19:39
     GIMP template and tutorial for designing business card satimis 13 May 03:21
      GIMP template and tutorial for designing business card Torsten Neuer 13 May 10:53
  GIMP template and tutorial for designing business card Murta 28 Dec 08:16
satimis
2008-05-10 02:15:09 UTC (over 17 years ago)
Hi folks,
I have been googling a while searching for Gimp template and tutorial to design business card without result, only Photoshop tutorial found. Can any folk point me to the right direction. TIA
B.R. satimis
Akkana Peck
2008-05-10 18:42:59 UTC (over 17 years ago)
satimis writes:
I've made business cards with GIMP: I wrote a script to generate an image of the right aspect ratio, then another script to take one such image and turn it into an image with the right aspect ratio to be a US-Letter sized page to print with gutenprint. (It also does various other types of labels, not just business cards.) You might have to adjust the offsets a bit for your templates and printer. Here are the scripts:
http://shallowsky.com/software/gimplabels/
To be honest, it's probably easier most of the time to use a program that's designed for making labels and business cards, like gLabels; or design one business card in gimp then import it into gLabels for printing (or Open Office, even). Anyway, lots of options.
...Akkana
satimis
2008-05-12 19:25:27 UTC (over 17 years ago)
satimis writes:
To be honest, it's probably easier most of the time to use a program that's designed for making labels and business cards, like gLabels; or design one business card in gimp then import it into gLabels for printing (or Open Office, even). Anyway, lots of options. [/quote]
Hi Akkana,
Thanks for your advice and script.
It is quite interesting. I can finish preparing and printing simple business cards on OOWriter. For professional cards with graphics, I'm now search a solution to edit it on different layers and merge them after finish. If I found a solution to the same then I can edit professional business cards on OOWriter. Otherwise I have to do the work on GIMP or Inkscape and import the image on OOWriter for printing.
I did lot of graphics editing >10 years ago before turning to Server side, working on CorelDraw, Corel PhotoPaint, PhotoShop, Illustratior, etc. Because I don't expect injecting too much time and effort on this simple task, I started searching around for a simple solution to finish the work with a few clicks.
B.R.
satimis
Chris Mohler
2008-05-12 19:39:25 UTC (over 17 years ago)
On Mon, May 12, 2008 at 12:25 PM, satimis wrote: [...]
Another layout program out there is scribus - not sure if runs well on windows though (they've been working on that for a while).
Chris
satimis
2008-05-13 03:21:57 UTC (over 17 years ago)
Hi Chris,
Thanks for your advice.
I suppose "scribus" is similar to PageMaker, FrameWork, Ventura, etc., a desktop publisher. I went across it before but never use it. I ran PageMaker while I lived in Windows world long time ago.
Actually the bar preventing me to edit professional business cards on OOoWriter is without layers there. I can insert picture/image on its template as background making it x% transparent according to my requirement. I can edit text on its top. But I can't insert another picture/image on top. Unless I treat it on OOoDraw. In this way I prefer going back to GIMP to do the job. I'm stuck there.
I'm running 100% Open Source packages here on Linux/Unix boxes. I don't have Windows box. To running Windows application I need "wine". It is in a very rare case except IE, the buggy Internet browser. Some Internet sites require visitors running IE. It is rather funny.
B.R. satimis
Torsten Neuer
2008-05-13 10:53:21 UTC (over 17 years ago)
If you've worked with PM back then, you'll probably have no problem with scribus.
There also is another bar, I suppose, when you have to have the cards printed with offset printers. Again, scribus is the solution. OOo is nice for the occasional home office cards though, that you can print on those pre-cut card sheets - but that's not the professional way.
Scribus is multi-platform. Should be no problem for you when you run Linux (just make sure that you have properly working fonts as scribus can be quite picky about incomplete font sets which sometimes are to be found in free/shareware fonts).
Not funny I'd say - but that'd lead off-topic ;-)
Torsten
2011-12-28 08:16:33 UTC (over 13 years ago)
I found another one with step-by-step instructions how to create a simple geeky business card with GIMP on http://www.inforbiro.com/blog-eng/how-to-create-a-business-card-with-gimp/
Hi folks,
B.R.
satimis
