Help with python-fu
Help with python-fu Alussam 17 Feb 20:41
  Help with python-fu Ofnuts 17 Feb 23:30
   Help with python-fu Alussam 18 Feb 16:40
  Help with python-fu ReginaLeo 29 Apr 16:18
   Help with python-fu ReginaLeo 29 Apr 16:19
2020-02-17 20:41:12 UTC (about 4 years ago)
Help with python-fu
Hello! I need some help with writing simple plugin. I tryed to use ready to use plugin code from https://www.gimp.org/docs/python/index.html. But when I used it, seems nothing happens. So I made a simple script, which prints message. But nothing works seems. Please,whatch video for details: https://youtu.be/0vpPaIEUGGE
Thanks for help.
Attachments: * https://www.gimpusers.com/system/attachments/1371/original/script
Alussam (via www.gimpusers.com/forums)
2020-02-17 23:30:28 UTC (about 4 years ago)
Help with python-fu
Thanks for help.
Your script registers (shows up in menus, listed in pluginrc), so you have it basically right.
When you run it you get his message (may require to use Gimp-console if you are on Windows):
Traceback (most recent call last): File "/app/lib/gimp/2.0/python/gimpfu.py", line 857, in _run res = apply(func, params[1:])
TypeError: crop_all_layers() takes exactly 1 argument (2 given)
This is because your function takes one single argument ("image"), and since your plugin is using old-style registration, an image and a layer are always implied as the first two arguments, so you need at least two arguments in your function (and you can ignore the second).
A better approach is to use new-style registration. In this registration model, the menu entry is split in two: the menu label as before, but without any path, and a named "menu" argument with the path:
Old style:
register( "crop-all-layers","","","Alex","Alex","2020", "/Filters/Artistic/_croplayers...", "RGB*, GRAY*",
crop_all_layers,
New style:
register(
"crop-all-layers","","","Alex","Alex","2020", "_croplayers...",
"RGB*, GRAY*",
crop_all_layers,
menu="/Filters/Artistic/"
However with the new style registration, there are no implicit arguments, so you have to declare your image argument:
register( "crop-all-layers","","","Alex","Alex","2020", "_croplayers...",
"RGB*, GRAY*",
[(PF_IMAGE, "image", "Input image", None)], [],
crop_all_layers,
And then of course use a function that takes a single argument, the image.
Some hints to debug your scripts, especially if you are on Windows:
https://www.gimp-forum.net/Thread-Debugging-python-fu-scripts-in-Windows
PS: Couldn't see anything useful in your video, it is too fuzzy to see the labels. Best make static screenshots, and copy/paste any error messages as text.
2020-02-18 16:40:19 UTC (about 4 years ago)
Help with python-fu
Old style:
crop_all_layers,
New style:
register(
"RGB*, GRAY*",
crop_all_layers,
"RGB*, GRAY*",
crop_all_layers,
Thanks a lot! I will try it now
2021-04-29 16:18:16 UTC (almost 3 years ago)
Help with python-fu
Thanks for help.
Python is hard
2021-04-29 16:19:15 UTC (almost 3 years ago)
Help with python-fu
Python is hard
I would like to help you, but I am not good at writing. I can recommend a cheap assignment writing service for you that will solve your problem. I have been cooperating with this service for over a year, and I am very pleased with their services. I think you will also appreciate this service.
2021-04-29 16:19:47 UTC (almost 3 years ago)
Help with python-fu
I would like to help you, but I am not good at writing. I can recommend a cheap assignment writing service for you that will solve your problem. I have been cooperating with this service - https://www.essaygeeks.co.uk/cheap-assignment-writing-service/ for over a year, and I am very pleased with their services. I think you will also appreciate this service.
