SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution
28 of 28 messages available
SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Dirk 27 Jul 22:10
  SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Kasim Ahmic 28 Jul 18:35
   SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Alexandre Prokoudine 28 Jul 18:42
   SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Dirk 28 Jul 18:49
    SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Kasim Ahmic 28 Jul 18:58
     SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Paul Cartwright 28 Jul 21:23
      SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Bob Long 28 Jul 22:29
       SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Dirk 28 Jul 23:55
        SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Ofnuts 29 Jul 00:31
         SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Patrick Shanahan 29 Jul 00:46
         SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Paul Cartwright 29 Jul 01:20
          SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Bob Long 29 Jul 01:42
           SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Paul Cartwright 29 Jul 09:59
        SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Stephen Allen 29 Jul 02:29
         SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Alexandre Prokoudine 29 Jul 18:27
          SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Kokopalen 29 Jul 19:57
        SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Johan Vromans 29 Jul 06:21
         SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Richard Gitschlag 29 Jul 15:49
          SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Johan Vromans 29 Jul 18:23
          SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Liam R E Quin 01 Aug 13:14
           SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Richard Gitschlag 01 Aug 13:35
            SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Liam R E Quin 01 Aug 14:04
             SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Alexandre Prokoudine 01 Aug 14:15
             SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Michael Schumacher 01 Aug 14:19
              SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Chris Mohler 01 Aug 17:31
        SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Alexandre Prokoudine 29 Jul 06:26
        SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution Dirk 31 Jul 23:17
Dirk
2013-07-27 22:10:57 UTC (about 12 years ago)
it has now been months that Gimp developers seem to have decided that their "product vision" in Gimp2.8 (debian/unstable) is more relevant than the workflow of their users.
People who use Gimp *a lot* keep clicking "Save as" instead of "Export" because that is what they're used to. Because it is natural.
If you think that it is trivial to make that workflow mistake over and over - then you are a casual Gimp user and can stop reading.
If you use Google and search for "export save gimp" you can witness what happens when marketing takes over the development.
There seems to be this product-vision-apologetics that they can ignore their users because they are not getting paid by them anyway. Old user will just be replaced by new users. Nobody will notice that transition except in the feedback, which isn't monetary but just a few angry posts in the internet.
Since Debian (like all other distributions) will have to (or has to) update to Gimp2.8 in the stable branch I dedicated a chroot jail to Gimp2.6 and will explain here how you can do it yourself.
Creating a chroot jail for a single application is very easy.
# the directory in which the chroot jail will exist mkdir chroot_gimp2.6
# run debootstrap it will install a minimal debian and gimp2.6 # this will take a while
debootstrap --variant=minbase --include=gimp squeeze chroot_gimp2.6 ftp://ftp.debian.org/debian
# run gimp from inside the chroot jail chroot chroot_gimp2.6 gimp
Enjoy Gimp2.6 and the workflow you are used to.
No further updates/changes of your Distribution will take Gimp2.6 workflow away from you.
This will be reposted for your convenience when debian/stable switches to Gimp2.8.
Dirk
Kasim Ahmic
2013-07-28 18:35:22 UTC (about 12 years ago)
So what exactly does this do? Does it lock GIMP 2.6 onto your machine and not allow you to upgrade to 2.8, or what?
Sorry, I'm mainly a Windows user :P
Sent from my iPod
debootstrap --variant=minbase --include=gimp squeeze chroot_gimp2.6 ftp://ftp.debian.org/debian # run gimp from inside the chroot jail chroot chroot_gimp2.6 gimp
Dirk _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
2013-07-28 18:42:01 UTC (about 12 years ago)
Chroot allows running an operating system within an operating system, in an isolated environment. Typically this is done for security reasons.
http://libregraphicsworld.org
Dirk
2013-07-28 18:49:00 UTC (about 12 years ago)
chroot changes the root directory for the process (in this case Gimp) from "/" to another path.
debootstrap installs a minimal linux and Gimp 2.6 into that new root path. So you are running a distribution inside a distribution. But it is not like a VM because no hardware is emulated.
The distribution installed in the chroot jail won't be influenced by updates/changes of the distribution that is not in the chroot jail. So you will end up having Gimp 2.6 forever.
Dirk
Sent from my iPod
Dirk
2013-07-28 18:49:21 UTC (about 12 years ago)
https://en.wikipedia.org/wiki/Chroot
Sent from my iPod
Kasim Ahmic
2013-07-28 18:58:45 UTC (about 12 years ago)
Ahh I see. So would this allow the user to have two version of GIMP installed?
Anyway, if the save vs. export thing causes such a problem, then people could just install a plugin that removes the new functionality and restores the old one. That way, your workflow isn't affected and you get all the new features of 2.8.
Sent from my iPod
Dirk
Sent from my iPod
Paul Cartwright
2013-07-28 21:23:27 UTC (about 12 years ago)
go ahead, make my day, tell me how to add that functionality back..
Paul Cartwright
Bob Long
2013-07-28 22:29:36 UTC (about 12 years ago)
Paul Cartwright wrote,
As posted several times on this list:
http://www.shallowsky.com/software/gimp-save/
Personally, I've never used it.
Bob Long
Dirk
2013-07-28 23:55:16 UTC (about 12 years ago)
I did. It added /another/ menu point called "Save-export" or so and acts like "Save" used to do, after the image was exported once.
Needless to say I /still/ clicked on "Save as..." or "Save".
So it really did nothing for me except making the menu a little more confusing.
The whole situation boils down to the lack of character that is necessary for admitting a mistake and reversing this change in the workflow.
Dirk
2013-07-29 00:31:09 UTC (about 12 years ago)
You *click*? Never learned Ctrl-S or Ctrl-E? (and you can probably redefine the Ctrl-S shortcut to be 'file-export')
Patrick Shanahan
2013-07-29 00:46:21 UTC (about 12 years ago)
* Ofnuts [07-28-13 20:32]:
Undoubtedly a windoz uzer. Some of us learned to use a computer before there were mize or whatever...
(paka)Patrick Shanahan       Plainfield, Indiana, USA      HOG # US1244711
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
http://en.opensuse.org                           openSUSE Community Member
Paul Cartwright
2013-07-29 01:20:21 UTC (about 12 years ago)
I use command keys like CTRL-S, but not sure how to re-define it to save-export-clean..
Paul Cartwright
Bob Long
2013-07-29 01:42:53 UTC (about 12 years ago)
See if Edit|Keyboard Shortcuts helps!
Bob Long
Stephen Allen
2013-07-29 02:29:33 UTC (about 12 years ago)
It's a mistake only in the eyes of a vocal few, who never have used GIMP in a professional work-flow. It's not a huge change, so either adapt, change to a simpler editor, or get used to it. Staying with one version forever pretty much indicates that you're not using for complicated editing. So, GIMP probably isn't for you.
You posted this on the Debian-user list too I see.
Cheers,
Stephen, Toronto
My Google+ Profile | http://goo.gl/JbQsq
Johan Vromans
2013-07-29 06:21:40 UTC (about 12 years ago)
Dirk writes:
There's much to be said for the new behaviour. It would be better if Ctrl-E just used the filename and properties from the imported file. The first time it may even show a "File exists, overwrite" dialog. Currently, Ctrl-E and Shift-Ctrl-E open the same export dialog, which is a waste.
-- Johan
2013-07-29 06:26:41 UTC (about 12 years ago)
Just use Ctrl+S. It's handy.
You won't get anywhere by repeating that, and there's about 1K of people you are probably annoying with this right now. Try thinking beyond your own interests.
Paul Cartwright
2013-07-29 09:59:50 UTC (about 12 years ago)
save-export-clean..
thank you!
Paul Cartwright
Richard Gitschlag
2013-07-29 15:49:38 UTC (about 12 years ago)
To: gimp-user-list@gnome.org
Date: Mon, 29 Jul 2013 08:21:40 +0200 Subject: Re: [Gimp-user] SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution
Dirk writes:
-- Johan
Y'know, I cannot think of any situation in my personal workflow where Ctrl+E versus Ctrl+Shift+E creates a tangible difference in behavior.
This is a problem.
Johan Vromans
2013-07-29 18:23:57 UTC (about 12 years ago)
Richard Gitschlag writes:
Well...
make some changes
Shift-Ctrl-E
Enter
Enter
Enter
Compare this to:
gimp image.jpg make some changes
Ctrl-E
Enter
Enter
Enter
Spot the difference? Right, there's none.
For simple editing, it would be beneficial if the latter were:
Ctrl-E
Enter
-- Johan
2013-07-29 18:27:16 UTC (about 12 years ago)
What, the amazing
http://lists.debian.org/debian-user/2013/04/msg00265.html thread is back? Oh, Dirk :)
OTOH, thanks for posting the chroot howto. Sounds like future FAQ material.
Kokopalen
2013-07-29 19:57:11 UTC (about 12 years ago)
El 29/07/2013 20:27, "Alexandre Prokoudine" escribi:
What, the amazing
Looking at that link maybe Microsoft didn't hire that people. Probably they just exported them from their staff to save resources (sorry for the offtopic...).
Dirk
2013-07-31 23:17:46 UTC (about 12 years ago)
I see there is still some effort in dragging me into your narcissistic bickering.
You guys use the chroot howto I supplied or go with the new design.
End of story.
Dirk
Liam R E Quin
2013-08-01 13:14:28 UTC (about 12 years ago)
as with control-s and control-S, there's no difference the first time, only on subsequent times: control-shift-s (save as) and control-shift-e (export as) will prompt for a filename each time, whereas control-s and control-e will only prompt the first time, and not at all in the case of control-s where you opened an xcf file.
control-e prompts even the first time because overwriting your input jpeg file can cause data loss that can't be restored by undoing all changes to the start of the session and then overwriting the file. It's also because control-e and control-shift-e were used in previous versions of gimp for changing the window size to fit the image and changing the image zoom to fit the window, respectively, so many users would press them out of habit and risked suddenly overwriting a file. I think I was the first to request that change, when I accidentally destroyed a jpeg image from a photo shoot.
So yes, there are differences, or at least there are supposed to be differences, between ^e and ^E, as with ^s and ^S, and yes, the developers do listen to constructive suggestions and do change the code.
Best,
Liam
Richard Gitschlag
2013-08-01 13:35:27 UTC (about 12 years ago)
Subject: Re: [Gimp-user] SOLVED: export vs. save menu in gimp2.8 - simple and lasting solution From: liam@holoweb.net
To: strata_ranger@hotmail.com
CC: jvromans@squirrel.nl; gimp-user-list@gnome.org Date: Thu, 1 Aug 2013 09:14:28 -0400
You might have overlooked one minor (but critical) element about my workflow: I generally only do one image export per GIMP session. So EVERY export is "the first time"....
I did suggest that the export filename/options should be recorded as part of the XCF project data -- what say you to that?
Liam R E Quin
2013-08-01 14:04:30 UTC (about 12 years ago)
Yes, that's true.
I think it would be a good idea and probably not difficult, but I doubt any of the core developers are listening to this thread.
Enter it as a request for enhancement (RFE) in bugzilla, and then post to the developer list about it, as a possible enhancement for image export to improve workflow between sessions.
Liam
2013-08-01 14:15:35 UTC (about 12 years ago)
It's what Inkscape does with its own SVG files. Indeed, very useful.
Try gimp-developer@ or, better, IRC :)
2013-08-01 14:19:57 UTC (about 12 years ago)
Von: "Liam R E Quin"
The other way round, please - first discuss it on the list, and then enter an enhancement request into Bugzilla.
Chris Mohler
2013-08-01 17:31:26 UTC (about 12 years ago)
But not on this thread ;)
Chris
