Changing size of Tool Options box
Changing size of Tool Options box jnhines 11 Jan 19:40
  Changing size of Tool Options box devvv 11 Jan 19:57
   Changing size of Tool Options box jnhines 11 Jan 20:27
2013-01-11 19:40:41 UTC (almost 13 years ago)
My tool options area is tiny; I have to scroll through it and it's horrible. I haven't been able to figure out how to change it. Help?
Screenshot of what I mean here: http://i.imgur.com/z5dts.jpg
2013-01-11 19:57:23 UTC (almost 13 years ago)
There is a ruler between your tool options and the canvas. Drag it to the right, and you'll get more space.
2013-01-11 20:27:38 UTC (almost 13 years ago)
Thanks for your reply... Actually, when you click the ruler and drag, nothing moves. BUT, if you click the little margin to the left of the ruler and drag, VOILA! relief.
Thanks for the help.
