Use of lens distortion filter?
Use of lens distortion filter? Leonard Evens 03 Apr 22:36
  Use of lens distortion filter? Alexandre Prokoudine 04 Apr 00:30
Leonard Evens
2011-04-03 22:36:49 UTC (over 14 years ago)
I asked about this once before without too much luck. Let me try again.
I need to correct distortion from my 18-200 mm lens for my Nikon D80.
I can experiment with the controls until I get what looks reasonable, but it would be easier if I could find recommendations for settings of the lens distortion filter at different focal lengths for the lens.
I used to use a Panorama Tools plugin for gimp for which I found such recommendations, but I can't get that plugin to work with recent versions of gimp.
Of course I can experiment by photographing a grid at different focal lengths and different subject distances and using trial and error, and create myh own tables. But, I hope someone has already done that.
Finally, where can I find a description of the the algorithm that the filter uses. If I had that, it might simplify things. Usually these algorithms apply a polynomial (usually cubic) correction based on the radial distance from the center of the image. The parameters set the coefficients of the polynomial.
2011-04-04 00:30:02 UTC (over 14 years ago)
If you shoot to Raw, my suggestion is to use UI to LensFun in UFRaw. You just select lens, distance to object and you are done (unless you want tweaking variables that are the same as in panotools).
Additionally you can use darktable which has UI to LensFun as well, but can work on JPEG too. But then you have to use Linux :)
There are even more photographty tools on Linux that can make use of LensFun.
