Scale Constrained
Scale Constrained Jonathan Bartlett 05 Sep 18:09
  Scale Constrained Sven Neumann 07 Sep 13:05
Jonathan Bartlett
2003-09-05 18:09:23 UTC (about 22 years ago)
Scale Constrained
I wrote a small but useful script that will scale an image to best fit within a constrained size without affecting aspect ratio. It's a simple script, but I've found it quite useful as a component for other scripts, and thought it might be useful in GIMP at large. It's scheme right now, but I could code it in C if you would like:
http://www.eskimo.com/~johnnyb/computers/multimedia/
Also on that page is a templated images script, which is really, REALLY basic at the moment, but basically allows you to easily create image-based templates (think Print Shop). Anyway, eventually I'm going to make this into something which has the ability to intelligently search for pictures to plug in, a better UI, and a UI for creating templates. However, if someone else was interested it might go a bit faster :) I thought this would be useful enough that some of the developer community might want to be involved, so I posted here.
Anyway, let me know.
Jon
2003-09-07 13:05:09 UTC (about 22 years ago)
Scale Constrained
Jonathan Bartlett writes:
I might miss something obvious, but I think this can be easily achieved using the existing Scale Image GUI.
Please note that the term Template is already taken in GIMP-1.3. Templates are available in the File-New dialog and can be just an image size or even point to a template XCF to load.
