CMYK 16-bit print developer sought
5 of 6 messages available
CMYK 16-bit print developer sought Robin Rowe 23 Oct 21:11
  CMYK 16-bit print developer sought Robert L Krawitz 24 Oct 00:36
CMYK 16-bit print developer sought Robin Rowe 24 Oct 03:47
  CMYK 16-bit print developer sought Robert L Krawitz 24 Oct 03:59
  CMYK 16-bit print developer sought Leonard Rosenthol 24 Oct 05:50
E184QLN-0007X5-00@usw-sf-we... 07 Oct 20:21
Robin Rowe
2002-10-23 21:11:14 UTC (about 23 years ago)
I was reading today in the gimp-mailinglist Your dialog with Robert L. Krawitz on 26. september 2002. I hope You can decide for making together an print-plugin in filmgimp.
16 bit is an issue for any serious artist. I work with scanned 16bitimages for creating panoramas. I need to present them on the web and on paper too. Please help to come away from a simple 8bit-gimp. Good luck for your project at all.
How to proceed has not been resolved. The Film Gimp project is focused on motion picture applications. As you know from my exchange with Robert I would like to see addressed the well known Gimp shortcomings with print and CMYK. However, this is not an application area motion picture technology developers understand well and no one from print has offered to lead this mission.
If any developer has the expertise and interest to work on improving CMYK and 16-bit per component print please contact me or post a note to the filmgimp-developer list.
Thanks,
Robin --------------------------------------------------------------------------- www.LinuxMovies.org
http://filmgimp.sourceforge.net
www.OpenSourceProgrammers.org
Robert L Krawitz
2002-10-24 00:36:36 UTC (about 23 years ago)
Date: Wed, 23 Oct 2002 12:11:14 -0700
This can't really be lead from the print side. We'll have no problem with 16-bit and CMYK (although we don't currently support 16-bit RGB), but the GIMP side needs to spec an API for it.
Robin Rowe
2002-10-24 03:47:54 UTC (about 23 years ago)
Robert,
Hi. Thanks for the clarification.
What I meant was "print" in the magazine/book publishing sense, not gimp-print. A developer knowledgable in the print side of the business would help in building the right 16-bit CMYK stuff.
With a little more digging I discovered some email discussion with John Culleton in the archives describing using netpbm pnmtotiffcmyk (http://sourceforge.net/projects/netpbm/) for command line conversion.
> tifftopnm RGB.tiff | pnmtotiffcmyk > CMYK.tiff
Looking further I find pnmtotiffcmyk (http://sourceforge.net/projects/netpbm/) and CMYKTiff (http://www.acooke.org/jara/cmyktiff/). In theory someone could take that into a Film Gimp plug-in pretty easily, and that could output to gimp-print. Is that what we need?
Cheers,
Robin
cc: John Culleton --------------------------------------------------------------------------- www.LinuxMovies.org
Robert L Krawitz
2002-10-24 03:59:10 UTC (about 23 years ago)
Date: Wed, 23 Oct 2002 18:47:54 -0700
Robert,
> This can't really be lead from the print side. We'll have no problem > with 16-bit and CMYK (although we don't currently support 16-bit RGB), > but the GIMP side needs to spec an API for it.
OK. I should note that I'm basically only familiar at all with inkjets; other printers have very different characteristics.
I don't think this is the right approach for production, although for prototyping it may be of use. In order to be really useful as CMYK, it's necessary for all of the channels to be independently editable (e. g. to get a solid black on some printers it's necessary to use CMY+K; K alone won't do it). That isn't the case with this package. The right thing to do is very printer, ink, and paper dependent.
A static, simple CMY->CMYK conversion can do quite well for a lot of purposes, but it won't satisfy the real high end.
Leonard Rosenthol
2002-10-24 05:50:30 UTC (about 23 years ago)
Another option would be enhance the GIMP/.xcf coder module that I wrote for ImageMagick so that it can import 16bit Film Gimp images. Since ImageMagick already knows how to deal with 16bit data AND CMYK data - it would be the least amount of work.
Leonard
