GSoC Status
1 of 2 messages available
1379571010.2986.25.camel@ca... 19 Sep 07:07
  GSoC Status Victor Oliveira 19 Sep 07:07
Victor Oliveira
2013-09-19 07:07:08 UTC (about 12 years ago)
GSoC Status
Hi Carlos,
While I appreciate the work you did, it really falls short of what is expected of a GSoC.
That by itself wouldn't' be a problem if you had applied yourself to the project but it happened that you weren't able to deliver what you promised. Much to the contrary, you had few coding issues and was able to catch up stuff quickly at the beginning, so there was a lot of potential.
GSoC is not like a contract where you deliver stuff and that's it. You almost didn't interact with the GIMP community at all and just now appeared after mid-term. Frankly, it was embarrassing to send you emails asking about the work and have them unanswered, that's not acceptable.
That said, it's nothing personal and if you decide to go forward outside GSoC, which would be really great, I'll help you out.
Victor Oliveira On Sep 18, 2013 11:10 PM, "Carlos Zubieta" wrote:
Hi Victor,
I know it's been a long time since the last time I wrote to you. So I'll list all the progress I've had since then:
* I did a gegl-cl-random re-structuration so it fits better the gegl directory structure, as you mentioned. * I ported to gegl-random
- noise-hsv
- noise-cie-lch
* And added OpenCL support to
- noise-hurl
- noise-slur
- noise-pick
- alien-map
- red-eyed-removal
- dot
- posterize
* I fixed a bug in box-min and box-max causing a segfault. * Also, I've already ported noise-hsv and noise-cie-lch to OpenCL. But when I wanted to test them I realized that there is no CL support for those color spaces, since there are extensions in babl. So I think we need to discuss if there will be OpenCL support for the babl extensions.
* I tried to use gegl-tester but it's kind of limited (you can see the options in the gegl-tester.c file in the bin folder), so for now I'm still using a simple diff operation. I think I could extend gegl-tester to suit also our needs but I think we need to discuss this in the IRC.
* I'm working on add OpenCL to: - Checkerboard
- Grid
- Stretch-contrast
- Remap
But I have some questions. Since Checkerboard and grid are point_render_class and remap is point_composer3_class, I'm unsure if it is better to hide the iterators as you did in the point_filter_class or do it the same way we usually do in the filter_class; letting them inside the cl_process function. What do you think?
Also, this week I'm supposed to document the work tha needs documentation but I don't know if we really need documentation for this ports. What do you say?
The are various tasks to finish, but I'll be working on them even after the SoC, so don't hesitate to "let me homework" :P .
Cheers, Carlos Z.
