Tiles / Shaped Angular Gradients
Tiles / Shaped Angular Gradients Christopher Howard 09 Aug 10:32
  Tiles / Shaped Angular Gradients Øyvind Kolås 09 Aug 12:17
   Tiles / Shaped Angular Gradients Bill Skaggs 10 Aug 02:33
Christopher Howard
2012-08-09 10:32:07 UTC (about 13 years ago)
Hi. I sent an e-mail recently asking for information about the Gimp algorithm for generating the shaped angular gradients over arbitrary free shapes on the canvas. I did more digging in the source code and discovered the pertinent function in app/gimpdrawable-blend.c:
code: --------
(gdouble x,
gdouble y) {
Tile *tile;
gfloat value;
gint ix = CLAMP (x, 0.0, distR.w - 0.7); gint iy = CLAMP (y, 0.0, distR.h - 0.7);
tile = tile_manager_get_tile (distR.tiles, ix, iy, TRUE, FALSE);
value = 1.0 - *((gfloat *) tile_data_pointer (tile, ix, iy));
tile_release (tile, FALSE);
return value; }
However, this is rather obscure to me because it depends on a global PixelRegion data structure and "Tiles" for that structure being calculated before hand. Is there some one who could give me any helpful words of insight on this subject?
I am rather curious, imagining that if I where to write a function for calculating the value of any pixel in a shaped angular gradient in an arbitrary enclosed path, it would have something to do with finding the closest points in the enclosing path and actually calculating angles. But so far I haven't found anything like that in the Gimp code.
frigidcode.com
indicium.us
Øyvind Kolås
2012-08-09 12:17:53 UTC (about 13 years ago)
It sounds like there is a full "grayscale" pixel buffer with a (probably normalized) distance to the border stored for each pixel.
http://pippin.gimp.org/
gimp-developer-list@gnome.org
Bill Skaggs
2012-08-10 02:33:53 UTC (about 13 years ago)
I don't think that's the code that does the work. I believe the actual functional code is in app/paint-funcs/paint-funcs.c, in the function called shapeburst_region(). Good luck understanding it.
-- Bill
