Compositors
Compositors Calculemus 07 Jul 18:24
  Compositors Ville Sokk 07 Jul 19:31
   Compositors Calculemus 08 Jul 00:20
    Compositors Michael Henning 08 Jul 00:35
     Compositors Calculemus 08 Jul 08:15
Calculemus
2012-07-07 18:24:50 UTC (over 13 years ago)
Compositors
I am trying to understand the code for the compositor soft-light, in the file /gegl-0.2.0/operations/generated/soft-light.c.
I am not sure about line 25: aD = aA + aB - aA * aB;
What is aD, is it alpha channel? Does gegl assume that the input image buffers are RGBA?
Thanks
Ville Sokk
2012-07-07 19:31:54 UTC (over 13 years ago)
Compositors
Thanks
_______________________________________________ gegl-developer-list mailing list
gegl-developer-list@gnome.org
https://mail.gnome.org/mailman/listinfo/gegl-developer-list
Just above the process function you can see the prepare function which sets input, aux and output buffers to RaGaBaA which is RGBA with premultiplied alpha.
Calculemus
2012-07-08 00:20:59 UTC (over 13 years ago)
Compositors
What source is used for the math? I see the original Adobe reference uses different math for the compositors like soft-light. Not sure which math to use, the one you guys have in GEGL or the one in the Adobe reference, which is used in Photoshop and After Effects, etc.
Michael Henning
2012-07-08 00:35:25 UTC (over 13 years ago)
Compositors
Note the comment at the top of that file:
/* SVG rendering modes; see: * http://www.w3.org/TR/SVG12/rendering.html * http://www.w3.org/TR/2004/WD-SVG12-20041027/rendering.html#comp-op-prop *
* aA = aux(src) alpha aB = in(dst) alpha aD = out alpha * cA = aux(src) colour cB = in(dst) colour cD = out colour */
It's also probably useful to note that these operations are generated by svg-12-blend.rb, so you might be better off looking there for some of the code.
-- drawoc
Calculemus
2012-07-08 08:15:56 UTC (over 13 years ago)
Compositors
Yep I saw that. I see different math being used for these compositors in different places. But I guess I can trust w3 :) and gegl
