[GSoC] GimpSizeEntry widget
[GSoC] GimpSizeEntry widget Martin Nordholts 30 May 09:29
Martin Nordholts
2011-05-30 09:29:40 UTC (over 14 years ago)
2011/5/30 Enrico Schröder :
Martin Nordholts
30. Mai 2011 11:04
Hi again
How's it going?
Best regards, Martin
Hi Martin,
sorry for the long pause, finished my exams last week (with moderate success...) ;)
Been working on the widget again to get it ready for the initial upload. Many things are missing and incomplete, but basic parsing and communication between two entries is functional. Right now I'm working on integration of the GimpUnit system into the GimpEevl unit resolver callback. I also updated the schedule on TaskTaste into smaller steps. Not everything is listed there, but I will add tasks as soon as they come to my mind. Maybe I will do the initial commit later today. Will my repository be set up or can I do that manually?
Best regards, Enrico
Hi
I hope the exams went well after all ;)
You got your GNOME git keys, right? If so, you can create a feature branch yourself in the GIMP git.
# create your local branch git checkout -b local-branch origin/master # Do some changes...
# Create/push to the feature branch git push origin local-branch:soc-2011-gimpsizeentry
# Every now and then git merge origin/master
I would like task sizes at http://tasktaste.com/projects/enni/gimpsizeentry to be at most 1 week so we have a chance to follow up on the progress. Once you have created your branch, I will set up our nightly builder at http://gimptest.flamingtext.com:8080/ to create nightly tarballs of your branch so people can easily try it out.
Looking forward to look at your first pushed commit :)
Note that I CC:ed gimp-developer
Regards, Martin
My GIMP Blog:
http://www.chromecode.com/
"GIMP 2.8 schedule on tasktaste.com"
Gimp-developer mailing list
