Fade has a blocking dialog
Fade has a blocking dialog Olivier 04 Oct 15:01
  Fade has a blocking dialog Sven Neumann 04 Oct 20:38
   Fade has a blocking dialog Olivier 04 Oct 21:36
Olivier
2010-10-04 15:01:34 UTC (about 15 years ago)
I'm not sure whether this is a bug or a feature: although most GIMP dialogs are not-blocking ones (i.e. you can leave the dialog open and do something else), the Image: Edit -> Fade dialog is blocking. It happens in the current git version, but maybe also in the stable version.
2010-10-04 20:38:26 UTC (about 15 years ago)
That's intentional. Due to the way that Edit->Fade is implemented, the user must not do anything else while this dialog is opened.
Olivier
2010-10-04 21:36:40 UTC (about 15 years ago)
2010/10/4 Sven Neumann
I suspected so, but it was just to be sure.
