Wish: A better animation system inside GIMP
9 of 9 messages available
Wish: A better animation system inside GIMP LightningIsMyName 29 Aug 09:01
  Wish: A better animation system inside GIMP Olivier 29 Aug 09:15
   Wish: A better animation system inside GIMP LightningIsMyName 29 Aug 09:37
    Wish: A better animation system inside GIMP Alexandre Prokoudine 29 Aug 10:05
    Wish: A better animation system inside GIMP Olivier 29 Aug 10:37
     Wish: A better animation system inside GIMP Jim Michaels 04 Oct 10:24
      Wish: A better animation system inside GIMP Øyvind Kolås 04 Oct 12:24
  Wish: A better animation system inside GIMP Martin Nordholts 29 Aug 19:57
   Wish: A better animation system inside GIMP Daniel Pinheiro Lima 30 Aug 15:52
LightningIsMyName
2010-08-29 09:01:49 UTC (about 15 years ago)
Currently, creating animations in GIMP is not done in a very clean way. To specify the duration of each frame and to specify whether it should stay or be hidden after that period, we abuse the layer names. Until recently we also had a limit of one layer per frame so we couldn't have had a frame composed out of several layers (so maintaining the frames had to be done in other files), but now layer groups can solve this (so the animation process is now a bit better).
I'm posting here a small wishlist regarding using GIMP for animations, to get the general approval before posting it as an enhancement request in bugzilla:
* More supported frame disposal modes - GIF has 3 frame disposal modes (taken from
http://www.webreference.com/content/studio/disposal.html ): 1. "Leave" - after the period of the frame has ended, the frame's pixels will remain visible and the next frames will be displayed on top of it. This mode IS supported in GIMP. 2. "Restore Previous" - after the period of the frame has ended, the frame's pixels will become transparent and will allow to see what was in that region before the current frame covered it. This mode IS supported in GIMP.
3. "Restore Background" - after the period of the frame has ended, the rectangle of that frame will be replaced by a transparent rectangle. It's similar to "Restore Previous", except for the fact that after the frame disappears you won't be able to see what was below it. This mode IS NOT supported in GIMP, and this is the mode I want to add. Supporting this mode means modifying the gif load/save plugin, the animation preview plugin and possibly the un/optimize plugins.
* A better animation editing modes. Abusing the layer modes is a very bad way to do this (at least in my opinion) - see a similar case in https://bugzilla.gnome.org/show_bug.cgi?id=344910 comment 3. We should remember the animation parameters using parasites, and by having some animation editor plugin (which leads to my next point - an animation editor)
* GIMP should have an animation editor which is integrated with a preview of the animation. Editing the animation and then closing the editor just to open the preview plugin is a very bad workflow. You should be able to preview from the same place you edit. Also, the editor should allow to edit the parasites of the layers which include the animation parameter. I have something in mind similar to MS Gif Animator (http://en.wikipedia.org/wiki/Microsoft_GIF_Animator), or anything with a similar simple UI.
This is how I imagine the animation workflow with GIMP - I'll appreciate some feedback.
~LightningIsMyName
Olivier
2010-08-29 09:15:53 UTC (about 15 years ago)
You seem to be interested only in animated GIF?
Even in this case, are you aware of the GIMP Animation Package?
Olivier Lecarme
LightningIsMyName
2010-08-29 09:37:30 UTC (about 15 years ago)
Forgot to mention that it would also require to change most animation scripts and GAP...
Olivier Lecarme
First of all, yes - I am aware of GAP and I used it several times (although I'm still not completely familiar with it).
Still, abusing layer names must stop and this is my main request - and in order to stop this we must introduce a very simple animation editor (since we have many animation scripts and it should be possible to edit their result). GAP is very good and complicated, and I'm referring to something much simpler only to edit the frame duration/disposal (instead of the ugly layer name hack) - nothing more.
~LightningIsMyName
2010-08-29 10:05:13 UTC (about 15 years ago)
With keyframing, presumably?
Olivier
2010-08-29 10:37:40 UTC (about 15 years ago)
2010/8/29 LightningIsMyName
Olivier Lecarme
GAP is not very complicated, simply it is not well described.
If you are interested in multi-layer animations, the duration and mode of layers is obviously a layer property. Why not use the layer name for this? It is available and not very useful for anything else in this precise case.
Martin Nordholts
2010-08-29 19:57:37 UTC (about 15 years ago)
That's not a problem since creating animations is not a defined goal in the GIMP product vision. I rather think we should remove support for animations in GIMP for 3.0, plug-ins can supply that functionality instead.
/ Martin
2010-08-30 15:52:02 UTC (about 15 years ago)
Hi guys,
I'm pretty aware that animations are not the goal in GIMP, however, I'm working in the past five years with GIMP to produce animations. Anyway, the thing is, I believe that the GIMP-GAP can goes forward and replace the animation filters completely. The animation filter is a great light-table tool, is pretty useful and we don't have something similar in GAP. Is not the right moment to remove or replace the animations filter, and maybe the right time to notice that the animation is a real function of GIMP and assume this as part of the product vision.
Cheers
Jim Michaels
2010-10-04 10:24:24 UTC (about 15 years ago)
in GAP I would like to see
- repaired .APNG support (import and export) - .MNG (import and export)
- numbered .BMP's as frames (used in a number of video frame conversion programs) (import and export)
- .AVI (import and export, but you can limit the kinds of video formats you want to support, since there are MANY)
- .flv (import and export) (I think it already does this) - .swf (import and export)
and if someone really feels like doing it, .mpg and .vp8 files and some of the modern formats.  I believe mplayer can read a lot of these formats, and what mplayer does not read, ffmpeg does. ffmpeg even does AVI[MJPEG] which is what my camera puts out.
Jim Michaels
jmichae3@yahoo.com
JimM@JimsComputerRepairandWebDesign.com http://JimsComputerRepairandWebDesign.com http://JesusnJim.com (my personal site, has software) http://DoLifeComputers.JesusnJim.com (group which I lead) ---
Computer memory/disk size measurements: [KB KiB] [MB MiB] [GB GiB] [TB TiB]
[10^3B=1000B=1KB][10^6B=1000000B=1MB][10^9B=1000000000B=1GB][10^12B=1000000000000B=1TB]
[2^10B=1024B=1KiB][2^20B=1048576B=1MiB][2^30B=1073741824B=1GiB][2^40B=1099511627776B=1TiB]
Note: disk size is measured in MB, GB, or TB, not in MiB, GiB, or TiB.  computer memory (RAM) is measured in MiB and GiB.
To: LightningIsMyName
Cc: gimp-developer@lists.xcf.berkeley.edu
Sent: Sun, August 29, 2010 1:37:40 AM
Subject: Re: [Gimp-developer] Wish: A better animation system inside GIMP
>scripts and GAP...
>> Olivier Lecarme
>more.
Øyvind Kolås
2010-10-04 12:24:53 UTC (about 15 years ago)
- .AVI (import and export, but you can limit the kinds of video formats you want to support, since there are MANY) - .flv (import and export) (I think it already does this) - .swf (import and export)
GEGL being a graph based image processing/compositing framework is lends itself well for building animation based systems as well as static image things like GIMP. One of the projects that I abandoned development of and folded into GEGL when GEGL development was restarted some years back was a combined video sequencing/compositing system. Some of the examples in the GEGL source tree are also simple animations driven from C or ruby/python.
GEGL has input nodes and output nodes built on top of the ffmpeg libraries (quite probably bitrotted, but salvagable). Perhaps similar nodes should be created along the same pattern as well that use GStreamer instead.
/Øyvind K.
