to devs from a translator
to devs from a translator Marco Ciampa 07 Jul 18:41
  to devs from a translator Alexandre Prokoudine 07 Jul 20:20
  to devs from a translator Sven Neumann 07 Jul 20:58
   to devs from a translator LightningIsMyName 08 Jul 07:58
    to devs from a translator Marco Ciampa 08 Jul 11:19
    to devs from a translator Sven Neumann 08 Jul 23:52
Marco Ciampa
2010-07-07 18:41:06 UTC (over 15 years ago)
Please differentiate more the strings.
For example the "None" string has many meanings in English that in Italian correspond to different words. Unfortunately "None" is used in many different context so it's difficoult, if not impossible, to give the translation the exact meaning that it deserve.
Please split strings more!
2010-07-07 20:20:29 UTC (over 15 years ago)
You see, you say that the problem exists, but you don't say where exactly :)
2010-07-07 20:58:10 UTC (over 15 years ago)
We can easily add context to strings where necessary. The framework for this is there and it is being used. We just need the translators to tell us exactly where translation context is needed. Preferably open bug reports for this.
LightningIsMyName
2010-07-08 07:58:08 UTC (over 15 years ago)
Hello
I also had this issue with translating to Hebrew, and so I recently added some context to the strings of the undo descriptions.
Marco: There is a really easy way to add these contexts - I can show you how if you'd like (or you can take a look at the patch I submitted here http://git.gnome.org/browse/gimp/commit/?id=5930b13084497d8720ac3b0c51daa0d0ffe4bdda ). Usually when translating GIMP, I discovered that's it enough to look at the source code to understand what most strings are from the name of the functions they appear in. Usually, looking at the code is enough if you know just a bit of programming (even if it's in a different programming language), usually you can manage without knowledge of how GIMP's code work.
Sven: I think this should somehow be handled for the future - what's the best place to leave a note to developers/commiters that before commiting new strings they should add some contexts for their strings? If we don't do this, we will have this problem of mis-translation continue to appear every time new strings are introduced...
~LightningIsMyName
Marco Ciampa
2010-07-08 11:19:05 UTC (over 15 years ago)
On Thu, Jul 08, 2010 at 08:58:08AM +0300, LightningIsMyName wrote:
Hello
~LightningIsMyName
Many thanks one example is worth a thousand words...I see that the context strings of gettext is exactly what I was looking for.
One typical example is here:
from po-plugins/it.po
#. if and how to center the image on the page #: ../plug-ins/common/align-layers.c:423 ../plug-ins/common/align-layers.c:454 #: ../plug-ins/common/cml-explorer.c:165 ../plug-ins/common/file-ps.c:3242 #: ../plug-ins/common/file-ps.c:3254 ../plug-ins/common/file-psp.c:646 #: ../plug-ins/file-fits/fits.c:1044 #: ../plug-ins/fractal-explorer/fractal-explorer-dialogs.c:998 #: ../plug-ins/fractal-explorer/fractal-explorer-dialogs.c:1039 #: ../plug-ins/fractal-explorer/fractal-explorer-dialogs.c:1080 #: ../plug-ins/lighting/lighting-ui.c:415 #: ../plug-ins/print/print-page-layout.c:461 msgid "None"
msgstr "No"
waaaayyyy too many contexts for that string!
Example:
align-layers.c = (IT) allineamento livelli -> None = No or Nessuno (ok!) file.psp.c = (IT) compressione dati -> No or Nessuna (ok!) fractal-explorer-dialogs.c = (IT) composizione -> Nessuna or No (ok!) ....
lighting-ui.c = (IT) tipo luce -> Nessuna (no! ---> I or someonelse will add some context strings)
Now I know how to do it.
Thant you very much to pointing me to the right direction...
2010-07-08 23:52:59 UTC (over 15 years ago)
We certainly don't want to do this for any new string that is added. If you like you can add a note to README.i18n though and suggest that strings which are likely going to be troublesome should have translator context added.
