GIMP Compatiblity with gtk+-2.90.x
GIMP Compatiblity with gtk+-2.90.x BugByteMan 06 Jul 21:08
  GIMP Compatiblity with gtk+-2.90.x Michael Natterer 07 Jul 00:28
BugByteMan
2010-07-06 21:08:36 UTC (over 15 years ago)
GIMP (git) is not currently compatible with gtk+2.90.x versions (gtk+-3.0).
The first error I ran into is the use of deprecated functions:
  CC     gimpbrowser.lo In file included from gimpwidgets.h:75:0,                  from gimpbrowser.c:30: ../libgimpwidgets/gimpunitmenu.h:48:3: error: expected specifier-qualifier-list before 'GtkOptionMenu'
../libgimpwidgets/gimpunitmenu.h:65:3: error: expected specifier-qualifier-list before 'GtkOptionMenuClass'
make: *** [gimpbrowser.lo] Error 1
What are the plans to make GIMP (git) compatible with the gtk+?
-- BugByteMan
Michael Natterer
2010-07-07 00:28:40 UTC (over 15 years ago)
On Tue, 2010-07-06 at 12:08 -0700, BugByteMan wrote:
GIMP (git) is not currently compatible with gtk+2.90.x versions (gtk +-3.0).
CC gimpbrowser.lo
In file included from gimpwidgets.h:75:0, from gimpbrowser.c:30: ../libgimpwidgets/gimpunitmenu.h:48:3: error: expected specifier-qualifier-list before 'GtkOptionMenu' ../libgimpwidgets/gimpunitmenu.h:65:3: error: expected specifier-qualifier-list before 'GtkOptionMenuClass' make: *** [gimpbrowser.lo] Error 1
GIMP 2.x is a GTK+ 2.x application, GIMP 3.x will be a GTK+ 3.x application.
We guarantee the same API and ABI compatibility for our plug-ins as GTK+ does, so we can't move to GTK+ 2.90 now.
After GIMP 2.8 (which will use GTK+ 2.22) is out, we will move to GTK+ 3.x (and thus GIMP 3.x).
Besides, why are you bulding GIMP against GTK+ git master anyway, GTK+ master is currently not good for anything but developing GTK+ 3.0 itself, and porting applications to it. You should stick with the gtk-2-22 branch if you want bleeding edge of the GTK+ you are used to.
ciao, --mitch
