REQ: Mass-tagging of resources?
REQ: Mass-tagging of resources? Renan Birck 17 Aug 06:39
  REQ: Mass-tagging of resources? Aurimas Juška 17 Aug 10:05
   REQ: Mass-tagging of resources? Renan Birck 17 Aug 18:48
Renan Birck
2009-08-17 06:39:54 UTC (about 16 years ago)
I successfully installed GIMP 2.7.0 on my Arch Linux system [1], mainly to test the new features.
However, tagging a lot of resources one-by-one is an annoying task, esp. when one downloads - say - a set of brushes.
Is there some way (or, if not, would it be possible to add one) of tagging many resources at the same time? (e.g. doing a multiple-selection and then adding the same tags to all selected ones?)
Thanks!
[1] I can provide the PKGBUILDs if anybody wants.
Aurimas Juška
2009-08-17 10:05:23 UTC (about 16 years ago)
We are aware that this feature is important for resource tagging and it is one of the tasks planned for the 2.8 release. Actually, it is in progress now and should be available soon. However, at the moment it is not possible to tag multiple resources at once as it is not even possible to select multiple items at once. As a temporary workaround, it might be faster to edit tags.xml located in ~/gimp-2.7/ manually using text editor.
Aurimas
Renan Birck
2009-08-17 18:48:40 UTC (about 16 years ago)
For the time being it's OK, then. Thank you for the info.
