Gimp-developer Digest, Vol 83, Issue 25
| mailman.5.1250449203.31407.... | 07 Oct 20:27 | |
| Gimp-developer Digest, Vol 83, Issue 25 | Ramón Miranda | 16 Aug 21:07 |
Nice update ,i see my brushes work faster. I think this update is a good work. i am still testing it.
regards
2009/8/16
Send Gimp-developer mailing list submissions to gimp-developer@lists.XCF.Berkeley.EDU
To subscribe or unsubscribe via the World Wide Web, visit https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-developer or, via email, send a message with subject or body 'help' to gimp-developer-request@lists.XCF.Berkeley.EDU
You can reach the person managing the list at gimp-developer-owner@lists.XCF.Berkeley.EDU
When replying, please edit your Subject line so it is more specific than "Re: Contents of Gimp-developer digest..."
Today's Topics:
1. ANNOUNCE: GIMP 2.6.7 (Sven Neumann)
Message: 1 Date: Sat, 15 Aug 2009 23:02:56 +0200 From: Sven Neumann
Subject: [Gimp-developer] ANNOUNCE: GIMP 2.6.7 To: GIMP Announce , gimp-devel , gimp-user
Message-ID:
Content-Type: text/plain; charset="UTF-8"GIMP 2.6.7 comes with lots of bug-fixes and it contains an important fix for using GIMP with the latest GEGL and babl releases. The source code can be downloaded from ftp.gimp.org or from one of the mirrors listed at http://gimp.org/downloads/#mirrors. Binary packages are already available for many platforms; please check the Downloads section at www.gimp.org.
We recommend that you also update GEGL and babl to the latest released versions, see http://gegl.org/
Overview of Changes from GIMP 2.6.6 to GIMP 2.6.7 =================================================
* Bugs fixed:
591017 ? Tablet pan is not working as fast as it should 577581 ? Crashes when using any colors tool/function on Windows 589667 ? GIMP crashes when clicking GEGL Operation on Windows 569833 ? file-jpeg-save erroneous with small quality values 590638 ? Changing palettes from list to grid view loses "locked to dock" status
589674 ? "Send by Email" does not update "Filename" 589674 ? "Send by Email" does not update "Filename" 586851 ? Transparent BMP files fail to load 589205 ? help-browser uses deprecated (and sometimes broken) webkit call
582821 ? 'Sphere Designer' does not reset correctly... 570353 ? first time open of .svg file ignores the requested units 555777 ? Export to MNG animation fails 577301 ? Dithering with transparency is broken for "positioned" method 493778 ? metadata plug-in crashes on some images 567466 ? PNG comment not found if more than 1 tEXt chunks 585665 ? Exporting to PSD with a blank text layer creates a corrupt file
586316 ? Levels tool does not adjust output levels correctly if input levels are changed
569661 ? Import from PDF throws errors when entering resolution in pixels per millimetre
567262 ? Black pixels appear in "Spread" filter preview 554658 ? Path Dialog: Path preview pics not to see constantly 167604 ? gimp_gradient_get_color_at() may return out-of-bounds values 567393 ? Rectangle select tool size shrinks to 0 if size is larger than the image and the up or down arrow is pressed 587543 ? crash when invoking certain actions by keyboard shortcut 563029 - Closing maximized image doesn't restore document window size 585488 ? Perspective transformation on a layer with a mask causes crash 586008 - GIMP crashes when right-click canceling a drawing action initiated outside layer boundaries 584345 ? when printing, the number of copies should be reset to 1 557061 ? Alpha to Logo
472644 ? Rotate with clipping crops the whole layer 577575 ? transform tool fills underlying extracted area wrongly 555738 ? Image display is wrong after undoing canvas size 577024 ? help-browser plugin crashes when used with webkit 1.1.3 555025 ? Action GEGL box widgets weirdness* Updated and new translations:
Czech (cs) Danish (da)
German (de)
Spanish (es)
Basque (eu)
Finnish (fi)
Hungarian (hu)
Italian (it)
Gujarati (gu)
Japanese (ja)
Kannada (kn)
Marathi (mr)
Norwegian bokm?l (nb)
Oriya (or)
Portuguese (pt)
Romanian (ro)
Sinhala (si)
Swedish (sv)
Simplified Chinese (zh_CN)
Traditional Chinese - Hong Kong (zh_HK) Traditional Chinese - Taiwan (zh_TW)------------------------------
Gimp-developer@lists.XCF.Berkeley.EDU https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-developerEnd of Gimp-developer Digest, Vol 83, Issue 25 **********************************************
