Development in Gentoo
Development in Gentoo Christopher Howard 12 Aug 21:19
  Development in Gentoo Hal V. Engel 12 Aug 22:16
Christopher Howard
2009-08-12 21:19:29 UTC (about 16 years ago)
Hi. Is there anyone here doing GIMP development inside Gentoo? I very recently switched my development machine over from Debian to Gentoo. At the Gentoo forums they showed me how to use the overlays to get glib-2.21.4, but I didn't see an overlay for >=gegl-0.1.0 or >=babl-0.1.0.
If you could tell me how you went about installing recent versions of these two libs (within the Portage system) I be appreciative.
- -- Christopher Howard
http://indicium.us
http://theologia.indicium.us
I digitally sign /all/ my e-mails via PGP. If you receive any e-mail supposedly from me without my valid PGP digital signature, please take additional steps to verify the authenticity of the message. -----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqDFcEACgkQQ5FLNdi0BcWu/QCfVc8epSjy+Qmh7WnTDNfjO8ve 4jkAn2KDz1GJBz/FV1oRJ+Dsxxhoo/JV
=qUCH
-----END PGP SIGNATURE-----
Hal V. Engel
2009-08-12 22:16:32 UTC (about 16 years ago)
There are no overlays for these that I know of. The latest gegl and babl ebuilds in portage are for version 0.0.22. This bug report:
http://bugs.gentoo.org/show_bug.cgi?id=259851
has gegl-9999 and babl-9999 ebuilds to do svn builds which is probably what you really want anyway. Just drop them into your local overlay directory and you should be good to go.
As a general rule if you need an ebuild and you can't find an off the self ebuild in portage or a public overlay you will almost always find one in the bug reporting system. Also in many cases you can also just copy the existing ebuild into your local overlay and rename it (IE. change the version in the file name) and it will work. For details on using a local overlay check the documentation on the gentoo web site.
It also might be a good idea to open a bug report to ask for portage to be updated to have version 0.1.0 ebuilds.
Hal
