problem in compiling gegl
problem in compiling gegl Rahul 12 Mar 18:06
  problem in compiling gegl Martin Nordholts 12 Mar 18:09
  problem in compiling gegl Sven Neumann 12 Mar 19:27
  problem in compiling gegl devvv 13 Mar 11:58
2009-03-12 18:06:00 UTC (over 16 years ago)
hi all,
i have downloaded gegel and babl fron the following link ftp://ftp.gimp.org/pub/gegl/0.0/gegl-0.0.22.tar.bz2 ftp://ftp.gtk.org/pub/babl/0.0/babl-0.0.22.tar.bz2
But when i reach inside the unzip folder of gegl-0.0.22 through the command prompt and give the command ./configure ( the first step given for compiling on http://gegl.org/ ) in unzip folder of gegl-0.0.22
it gives the error
" babl package is not found
so make changes in the pkg-config or alternative is the set babl-cflags and babl-libs so that there is no need to call pkg-config "
so gegl.pc is not formed.
But when i give the same command in the unzip folder of babl-0.0.22 then it gives no error and inside it babl.pc is formed.
please tell me what should i do??????I have tried a lot but could not find the solution.What i tried is i add the path in the PKG_CONFIG_PATH, where i place babl-0.0.22.But of no use, it it giving same error.
thanx,
Martin Nordholts
2009-03-12 18:09:25 UTC (over 16 years ago)
Either you were not specific enough, or this is where your problem is. PKG_CONFIG_PATH should point to $PREFIX/lib/pkgconfig, not babl-0.0.22
- Martin
2009-03-12 19:27:23 UTC (over 16 years ago)
please read the pkg-config(1) manual page to make yourself familiar how this stuff works.
2009-03-13 11:58:43 UTC (over 16 years ago)
hi all,
it gives the error
thanx,
you first need to compile babl, set environment variables and then build gegl and gimp.
there is a short step by step instruction for how to do this with gimp 2.6 - but you can easily adept it to compile 2.7 as well.
http://www.gimpusers.com/news/2008-10-07/compile-gimp-260-for-ubuntu-804.html
hope that helps
