GIMP Print Dialog Box
7 of 7 messages available
GIMP Print Dialog Box WHITE,CURTIS (HP-USA,ex1) 09 Jul 14:59
  GIMP Print Dialog Box Sven Neumann 09 Jul 15:05
GIMP Print Dialog Box WHITE,CURTIS (HP-USA,ex1) 09 Jul 15:21
  GIMP Print Dialog Box Sven Neumann 09 Jul 16:52
GIMP Print Dialog Box WHITE,CURTIS (HP-USA,ex1) 17 Jul 17:29
  GIMP Print Dialog Box Guillermo S. Romero / Familia Romero 17 Jul 17:48
GIMP Print Dialog Box WHITE,CURTIS (HP-USA,ex1) 17 Jul 18:12
2002-07-09 14:59:36 UTC (almost 22 years ago)
How do I bypass the print dialog box in Gimp? I have written a batch script that works but the print box comes up and I wnt it to go straight to the printer. We have tried modifying the print.c and gimp_main_window.c code. Any assistance would be apreciated.
2002-07-09 15:05:01 UTC (almost 22 years ago)
"WHITE,CURTIS (HP-USA,ex1)" writes:
it should work the usual way: call the print procedure with run_mode set to GIMP_RUN_NONINTERACTIVE and pass the necessary parameters.
Salut, Sven
2002-07-09 15:21:03 UTC (almost 22 years ago)
Here is my script that I run in Script-Fu: (set! l3image (car (extension-screenshot 1 TRUE ""))) (file-print-gimp 0 l3image l3image "lp -s -dhpcp1160 -oraw" "DJ9xxVIP" "usr/share/printconf/foomatic/data/DJ9xxVIP-530418.foo" 1 "300" "Letter" "Plain" "Tray1" 1 100 -1 -1 -1 1 1 1 1 1 0 2 2 1 "\0" "Adaptive" 0)
When I use 1 for run_mode it errors out. Thank you in advance for your help.
-----Original Message----- From: Sven Neumann [mailto:sven@gimp.org] Sent: Tuesday, July 09, 2002 9:05 AM To: WHITE,CURTIS (HP-USA,ex1)
Cc: 'gimp-developer@lists.xcf.berkeley.edu' Subject: Re: [Gimp-developer] GIMP Print Dialog Box
script
Salut, Sven
2002-07-09 16:52:22 UTC (almost 22 years ago)
passing the image_id as drawable_id doesn't look like a good idea...
did you check that the supplied parameters match the requirements? You can look the PDB call up in the DB Browser to check this.
BTW, if all you want to achieve is a print-out of your desktop, you should consider using something less complex than The GIMP.
Salut, Sven
2002-07-17 17:29:11 UTC (almost 22 years ago)
How do I get the title of the print preview window. I can get the window id with the xwininfo command. I want to pass the window name to a program called xvkbd. This program is a virtual keyboard that can send keystrokes to an application window. You have to pas it the window name or id. Since the id changes I need to send it the name. Any suggestions would be welcomed.
2002-07-17 17:48:07 UTC (almost 22 years ago)
curtis_white@hp.com (2002-07-17 at 1129.11 -0400):
Use xprop and cut out what you do not need.
GSR
2002-07-17 18:12:28 UTC (almost 22 years ago)
Is there a way to call a linux command within a script-fu script?
