help with git
Forums ► GIMP documentation (read-only) ► help with git
Marco Ciampa
(almost 3 years ago)
julien
julien
Ulf-D. Ehlert
Roman Joost
Ulf-D. Ehlert
Roman Joost
- Ulf-D. Ehlert (almost 3 years ago)
Roman Joost
Ulf-D. Ehlert
Roman Joost
Ulf-D. Ehlert
julien
Ulf-D. Ehlert
- Marco Ciampa (almost 3 years ago)
julien
Sent: 2009-04-19 17:17:52 UTC (almost 3 years ago)
help with git
I've successfully 'cloned' the gimp-help-2 repo in my brand-new portable.
Now, done the configure/make steps I see as modified with 'git status' all
po/it/* files.I see this:
$git status
# On branch master
# Changed but not updated:
# (use "git add ..." to update what will be committed)
# modified: po/it/appendix.po
# modified: po/it/concepts.po
# modified: po/it/dialogs.po
# modified: po/it/filters.po
# modified: po/it/filters/alpha-to-logo.po
# modified: po/it/filters/animation.po
# modified: po/it/filters/artistic.po
# modified: po/it/filters/blur.po
# modified: po/it/filters/combine.po
# modified: po/it/filters/decor.po
# modified: po/it/filters/distort.po
# modified: po/it/filters/edge-detect.po
# modified: po/it/filters/enhance.po
# modified: po/it/filters/generic.po
# modified: po/it/filters/light_effects.po
# modified: po/it/filters/map.po
# modified: po/it/filters/noise.po
# modified: po/it/filters/render.po
# modified: po/it/filters/web.po
# modified: po/it/gimp.po
# modified: po/it/glossary.po
# modified: po/it/introduction.po
# modified: po/it/menus.po
# modified: po/it/menus/colors.po
# modified: po/it/menus/colors/auto.po
# modified: po/it/menus/colors/components.po
# modified: po/it/menus/colors/info.po
# modified: po/it/menus/colors/map.po
# modified: po/it/menus/edit.po
# modified: po/it/menus/file.po
# modified: po/it/menus/help.po
# modified: po/it/menus/image.po
# modified: po/it/menus/layer.po
# modified: po/it/menus/select.po
# modified: po/it/menus/view.po
# modified: po/it/preface.po
# modified: po/it/toolbox.po
# modified: po/it/tutorial.po
# modified: po/it/using.po
# modified: po/it/using/preferences.po
# Untracked files:
# (use "git add ..." to include in what will be committed)
# .xml2po.mo
# AUTHORS
no changes added to commit (use "git add" and/or "git commit -a")But I haven't changed anything and I do not want to commit some timestamp
change.What can I do?
TIA
Marco Ciampa
| Linux User #78271 |
| FSFE fellow #364 |
Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
Sent: 2009-04-19 21:55:59 UTC (almost 3 years ago)
help with git
I cloned three times, and after running ./autogen.sh, I never had your
problem...Julien
> po/it/* files._______________________________________________
Sent: 2009-04-20 07:30:56 UTC (almost 3 years ago)
help with git
> problem...
>because I have not used 'make pot' up yet. I only pushed copy-pasted
ready files from my svn folder to the Git folder.I think this problem is due to 'make pot' that updates pot revision
dates in all pot files.Julien
Sent: 2009-04-20 12:54:28 UTC (almost 3 years ago)
help with git
julien (Montag, 20. April 2009, 07:31):
> dates in all pot files.We can add a 'touch -r srcfile potfile' to prevent 'make' updating the
po files.According to the autoconf manual, this may lead to "timestamp truncation
problems" on some "ancient" systems, but I think we should ignore this
until somebody reports a problem.Ulf
PS: I will (mis)use the doap file as a trainings object for learning
git. :-| @Roman: shouldn't the list of maintainers in the the doap file
be the same as in MAINTAINERS?_______________________________________________
Sent: 2009-04-20 13:20:49 UTC (almost 3 years ago)
help with git
> po files.
> Ulf
I actually thought the the doap file would be now *the* compulsory file
for managing maintainers. Thats why I added more than me to the doap
file as a maintainer.Appearently that is not the case. If you really need to, update the
MAINTAINERS file. I reckon it'll go away in the future...Cheers,
Roman Joost
www: http://www.romanofski.de
email: roman@bromeco.com_______________________________________________
Sent: 2009-04-21 12:44:10 UTC (almost 3 years ago)
help with git
Marco Ciampa (Sonntag, 19. April 2009, 17:17):
> $git status
> # On branch master
[...]> But I haven't changed anything and I do not want to commit some
> timestamp change.Try 'git checkout po/it' (don't know if it works recursively, otherwise
use "find po/it -name '*.po' | xargs git checkout"), this should revert
any changes and touch the po files, so that pot files are newer than
src files and po files are newer than pot files, which should
make 'make' happy again.Bye,
Ulf_______________________________________________
Sent: 2009-04-21 22:54:12 UTC (almost 3 years ago)
help with git
> > $git status
> > # On branch master
> > timestamp change.
> Bye,
> Ulf
Thank you Ulf, I've erased the entire local repository and re-make-d it. Now
'make' work as expected, many thanks again!bye
Marco Ciampa
| Linux User #78271 |
| FSFE fellow #364 |
Sent: 2009-04-27 13:27:35 UTC (almost 3 years ago)
help with git
Roman Joost (Montag, 20. April 2009, 13:20):
> file for managing maintainers. Thats why I added more than me to the
> doap file as a maintainer.
> Appearently that is not the case."DOAP is primarily intended for computer consumption..."
> If you really need to, update the MAINTAINERS file.
> I reckon it'll go away in the future...Why? It's a useful information at a prominent place, while
nobody will read 'gimp-help-2.doap'.Ulf
Sent: 2009-04-27 14:06:19 UTC (almost 3 years ago)
help with git
Hi Ulf,
My assumption was based on this mail:http://www.mail-archive.com/gnome-infrastructure@gnome.org/msg00894.html
Now, because that's already a year old, things must have been changed
already ...> > If you really need to, update the MAINTAINERS file.
I just saw both files read by the gnome infrastructure, not really by
people.Cheers,
Roman Joost
email: romanofski@gimp.org_______________________________________________
Sent: 2009-04-29 14:02:00 UTC (almost 3 years ago)
help with git
Roman Joost (Montag, 27. April 2009, 14:06):
>tmlAn interesting idea mentioned in that thread was generating MAINTAINERS
and AUTHORS from the doap file.Ulf
