Tool{box,tips}
What would you think about adding the shortcut keys to the
toolbox tooltips?
It seems like a natural fit. The "Tools" submenu underneath the
image right-click "Tools" does list the shortcut keys. However,
the tools I use most often are most easily identified by their
icons. These are the ones I would like to memorize the keyboard
shortcuts for most. I would like to be able to pause a moment
before I click the Toolbox's icon, see the tooltip, and slowly
memorize keybindings.
I can write a patch for this myself, if you would like (I think
it should just be a matter of concatenating the shortcut letter
to the existing blurb). I restrained just because I don't know
the code well enough to fit in, stylistically.
Many thanks,
- Ryan J. King
