(gimp-drawable-get-pixel)
(gimp-drawable-get-pixel) Zoran Bosnjak 13 Jul 18:02
  (gimp-drawable-get-pixel) Simon Budig 13 Jul 15:17
Simon Budig
2002-07-13 15:17:39 UTC (almost 22 years ago)
Zoran Bosnjak (zoran.bosnjak@email.si) wrote:
can someone please explain me how to use the result from (gimp-drawable-get-pixel) inside the scheme script?
The function gives me result like (4 #4"1d1d1dff"). How do I convert this result to more friendly form like '(255 127 0), so I could make some calculations with it?
The result is a list: Array-length and the array. You can access the elements of the array via (aref array index)
But keep in mind, that processing all pixels of an image with (gimp-drawable-get-pixel) is *slow*. You might want to use gimp-perl or write an plugin in C.
Bye, Simon
Zoran Bosnjak
2002-07-13 18:02:43 UTC (almost 22 years ago)
The second question is: What is the best way to calculate how one pixel match the other pixel by the color (result between 0-no match at all and 1-same color)? A simple scheme example would be great.
Thank you for your answer.
best regards, Zoran Bosnjak
