Plugins on GIMP 2.10
Plugins on GIMP 2.10 Gimp-Werkstatt 03 May 05:02
  Plugins on GIMP 2.10 Tobias Ellinghaus 03 May 07:55
   Plugins on GIMP 2.10 Gimp-Werkstatt 03 May 17:45
  Plugins on GIMP 2.10 Michael Natterer 04 May 13:12
   Plugins on GIMP 2.10 Gimp-Werkstatt 04 May 14:18
Gimp-Werkstatt
2018-05-03 05:02:15 UTC (about 6 years ago)
Hello everybody,
first of all I want to thank you for the great work you've done on the new GIMP it has become a great tool to play with and has a lot of new items to discover.
Yesterday I was playing around with it a little, to get to know the new tools a little. And I was trying to install some of my scrips and plugins. I'm afraid, they don't work. Will they have to be rewritten completely because of the great new features you've put in, or would it be a matter of fixing some strings in GIMP?
Thanks a lot
Anke
http://www.gimp-werkstatt.de
http://www.kompozer-web.de
http://www.kreativ-workshops.net
Tobias Ellinghaus
2018-05-03 07:55:53 UTC (about 6 years ago)
Am Donnerstag, 3. Mai 2018, 07:02:15 CEST schrieb Gimp-Werkstatt:
Hello everybody,
That depends on the scripts and the functions they call.
Thanks a lot
Anke
Gimp-Werkstatt
2018-05-03 17:45:22 UTC (about 6 years ago)
Hi Tobias,
I was trying to install the Script GIMP_animated_Fire by fens_post. Here is the download link -->
https://fence-post.deviantart.com/art/GIMP-Animated-Fire-Script-84921148
And I tried this one --> http://registry.gimp.org/node/87
At the gimp-werkstatt is another user, she tried some plugins Topaz-Filter, Fractalius von Redfield and Kaleidoscope2. She reported, that she can not install G'MIC yet, too.
So that was the reason I did not ask any special script or plugin.
Anke
Am 03.05.2018 um 09:55 schrieb Tobias Ellinghaus:
Hello everybody,
Thanks a lot
Anke
Michael Natterer
2018-05-04 13:12:39 UTC (about 6 years ago)
On Thu, 2018-05-03 at 07:02 +0200, Gimp-Werkstatt wrote:
Hello everybody,
items to discover.
Hi Anke,
what exactly is "they don't work"? Any error message? What exactly did you do to install the stuff?
Everything that doesn't work under 2.10 that worked under 2.8 would be a bug in GIMP, unless the plug-ins are somehow wrongly built, or are doing something that was actually forbidden even before (2.10 does some stricter error checking).
Regards, Mitch
Gimp-Werkstatt
2018-05-04 14:18:35 UTC (about 6 years ago)
Am 04.05.2018 um 15:12 schrieb Michael Natterer:
Hello everybody,
items to discover.
Hi Anke,
Regards, Mitch
Hi Mitch,
yes, if there was an error, I would of cours have told you. But there was non. It simply wasn't there.
I'm running GIMP on the new Xubuntu 18.04 installed via flatpak.
The script I usually only copy into the folder "scripts" in local user. Following the link in GIMP 2.10 Bearbeiten - Einstellungen - Ordner - Scripts (sorry. german), I have to put the script into  home/user/var/app/org.gimp.GIMP/cpmfog/GIMP/2.10/ The folder is empty, so I created the folder scripts and put a copy into the folder. Restarted GIMP, but the script is nowhere in any of the menus on GIMP neither in filter nor in animation. So there were no errors.
I tried it with different locations for the folder, because you can put the path to the folder into GIMP setting. But nothing worked. The script used to run on GIMP 2.8.
Thanks Anke
