[PATCH] Refine opencl implementation of operation weighted-blend
[PATCH] Refine opencl implementation of operation weighted-blend Yongjia Zhang 10 Feb 01:51
Yongjia Zhang
2014-02-10 01:51:11 UTC (almost 12 years ago)
Remove kernel cl_copy_weighted_blend, use clEnqueueCopyBuffer instead. It is three times faster than executing kernel cl_copy_weighted_blend based on my tests on Intel Beignet.
Signed-off-by: Yongjia Zhang ---
opencl/weighted-blend.cl | 8 -------- opencl/weighted-blend.cl.h | 8 -------- operations/common/weighted-blend.c | 17 +++++------------ 3 files changed, 5 insertions(+), 28 deletions(-)
diff --git a/opencl/weighted-blend.cl b/opencl/weighted-blend.cl index 68cec63..fd410c8 100644
--- a/opencl/weighted-blend.cl
+++ b/opencl/weighted-blend.cl
@@ -1,11 +1,3 @@
-__kernel void cl_copy_weigthed_blend(__global const float4 *in, - __global float4 *out) -{
- int gid = get_global_id(0);
- float4 in_v = in[gid];
- out[gid] = in_v;
__kernel void cl_weighted_blend(__global const float4 *in, __global const float4 *aux, __global float4 *out) diff --git a/opencl/weighted-blend.cl.h b/opencl/weighted-blend.cl.h index d516482..f849f10 100644
--- a/opencl/weighted-blend.cl.h
+++ b/opencl/weighted-blend.cl.h
@@ -1,12 +1,4 @@
static const char* weighted_blend_cl_source = -"__kernel void cl_copy_weigthed_blend(__global const float4 *in, \n" -" __global float4 *out) \n" -"{ \n" -" int gid = get_global_id(0); \n" -" float4 in_v = in[gid]; \n" -" out[gid] = in_v; \n" -"} \n" -" \n" "__kernel void cl_weighted_blend(__global const float4 *in, \n" " __global const float4 *aux, \n" " __global float4 *out) \n" diff --git a/operations/common/weighted-blend.c b/operations/common/weighted-blend.c index 707429f..91d8114 100644
--- a/operations/common/weighted-blend.c +++ b/operations/common/weighted-blend.c @@ -56,9 +56,7 @@ cl_process (GeglOperation *self,
if (!cl_data)
- const char *kernel_name[] = {"cl_copy_weigthed_blend", - "cl_weighted_blend", - NULL}; + const char *kernel_name[] = {"cl_weighted_blend", NULL}; cl_data = gegl_cl_compile_and_build (weighted_blend_cl_source, kernel_name); }
@@ -67,15 +65,10 @@ cl_process (GeglOperation *self,
if (!aux_tex)
- cl_err = gegl_clSetKernelArg(cl_data->kernel[0], 0, sizeof(cl_mem), (void*)&in_tex); - CL_CHECK;
- cl_err = gegl_clSetKernelArg(cl_data->kernel[0], 1, sizeof(cl_mem), (void*)&out_tex); - CL_CHECK;
- cl_err = gegl_clEnqueueNDRangeKernel(gegl_cl_get_command_queue (), - cl_data->kernel[0], 1, - NULL, &global_worksize, NULL, - 0, NULL, NULL); + cl_err = gegl_clEnqueueCopyBuffer(gegl_cl_get_command_queue(), + in_tex, out_tex, 0, 0, + sizeof(cl_float4)*global_worksize, + 0, NULL, NULL); CL_CHECK;
else
1.8.3.2
