Login and other functions on this site require JavaScript.
Forums ► About gimp.org (read-only) ► GimpBrush
Sent: 2011-11-12 09:21:29 UTC (6 months ago)
GimpBrush
permalink
Hello, how can i add my site with gimp brushes ( gimpbrush.com ) to "links" section on gimp.org ? Eugene.
Eugene.
Production: 2.8.0
Upcoming: 2.9.0
for Windows
» All downloads
Do/Did you have technical Problems with GIMP 2.8.0 or does everything run smoothly?
View results
Here I use similar principle to make color image from bw: http://x32.in.ua/?p=897 (but ...
Adding comments to an image (Alt+IEnter, and then "Comments") doesn't work. When I com...
For everyone having the "procedure entry point" issues, the old zlib1 is definitely the...
I had this problem too. The cause turned out to be an old copy of zlib1 in my systems f...
819 @ Twitter
