Gimp entry error
Gimp entry error muffinn 13 Sep 07:18
  Gimp entry error rich404 13 Sep 09:06
   Gimp entry error muffinn 13 Sep 18:14
2018-09-13 07:18:47 UTC (over 5 years ago)
Gimp entry error
Muliple errors of this type on entry. I have uninstalled and tidies registry... Any ideas?
Thanks
2018-09-13 09:06:15 UTC (over 5 years ago)
Gimp entry error
Thanks
Probable scenario:
You had the beautify plugin(s) installed in a previous Gimp 2.8 Gimp 2.10 copied the beautify files from the old Gimp 2.8 profile to the new Gimp 2.10 user profile. You might be able to sort that out.
I am not writing the whole thing out again in this mailing list format.
see: https://www.gimp-forum.net/Thread-Re-Beautify-Plugin
The alternative scenario: You used one of those 'multi-plugin' installers that dumped a load of files in the main Gimp folders, leaving them behind to screw up the new installation.
Start again, uninstall Gimp 2.10 Delete any C:\Program Files\GIMP 2 (if there) Delete the Gimp 2.10 user profile. Disable the old Gimp 2.8 profile. Install Gimp 2.10 Run it to make a new default Gimp 2.10 profile. Start adding scripts and plugins to the new profile, one at a time, to check what works (or not)
2018-09-13 18:14:42 UTC (over 5 years ago)
Gimp entry error
Thanks - brilliant
It was the hidden appdata that was the issue - now all OK
Many thanks
Probable scenario:
