RSS/Atom feed identi.ca Twitter
GIMP SWAP Folder not honored
11 of 11 messages available
GIMP SWAP Folder not honored stormy 12 Sep 16:20
  GIMP SWAP Folder not honored Jehan Pagès via gimp-user-list 16 Sep 19:41
   GIMP SWAP Folder not honored stormy 17 Sep 06:02
    GIMP SWAP Folder not honored Jehan Pagès via gimp-user-list 18 Sep 12:15
    GIMP SWAP Folder not honored gimp-users.mbourne@spamgourmet.com 18 Sep 19:40
     GIMP SWAP Folder not honored stormy 19 Sep 17:59
      GIMP SWAP Folder not honored Michael Schumacher 19 Sep 18:50
       GIMP SWAP Folder not honored gimp-users.mbourne@spamgourmet.com 19 Sep 20:45
        GIMP SWAP Folder not honored stormy 20 Sep 21:26
      GIMP SWAP Folder not honored gimp-users.mbourne@spamgourmet.com 19 Sep 20:42
  GIMP SWAP Folder not honored Liam R E Quin 18 Sep 16:37
2018-09-12 16:20:59 UTC (3 months ago)
contact
Send private message
On Windows 10, uninstalled 2.8.18, and reinstalled 2.10.6, however, the SWAP & Temporary folders, in Edit-Properties->Folders, do not appear to be honored.
Set the Temporary folder to F:\tmp and Swap folder to F:\swp, restarted GIMP, and PC...
however, no matter what, GIMP still goes to either:
c:\Users\myuser\.cache\gegl-0.4\12056-shared.swap
c:\Users\myuser\AppData\Local\Microsoft\Windows\INetCache\gegl-0.4\12056-shared.swap
That "C:" drive is low on space, only few GB, and drive F has a TB free :)
I've reinstalled many times, and removed all possible files from directories, and registry as per various urls online, however, no matter what, each new re-install, gimp ignores the folders settings, and writes directly to the above locations... any ideas?
Stormy.
2018-09-16 19:41:44 UTC (3 months ago)
Do you have any link for developers so that we know where to look for regarding this SWAP settings?
Keep in mind all the core devs do not use Windows, so do not hesitate to be accurate and consider we don't know much about Windows.
and PC...
Does it go to one or the other? I'm sure it does the right thing, but I doubt that it randomly use one folder or another at different runs, right? :-)
Yeah it obviously follows XDG folder (which is a spec for Linux distributions), and that is obviously not right for Windows. We should special case the cache directory for this OS. If you tell us more about this SWAP settings on Windows (and in particular what we have to look for? Is there an API to know this folder? An env variable), this would help. Also what is the proper default cache folder expected on Windows if none were explicitly set?
Please when you answer, mention me explicitly (I have filters) so that I don't miss your answer.
Thanks.
Jehan
Stormy.
stormy (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
ZeMarmot open animation film
http://film.zemarmot.net
Liberapay: https://liberapay.com/ZeMarmot/
2018-09-17 06:02:54 UTC (3 months ago)
contact
I'm not sure what you mean by "link", the "SWAP Folder" is a GIMP feature, it is located in EDIT->Preferences, then scroll down to FOLDERS, there are two options one "Temporary folder" and other is "Swap folder".
It never went to the location I set in the actual preferences dialog, instead it went into one or the other locations , that depended on the cleanup/reinstall sequence i took (did this many times), but once it chose a location , it kept using it for the duration of that install cycle.. if i were to cleanup and reinstall, it might choose the other location, but, never the one specified in the prefs.
I'm talking about GIMP's internal swap, not windows swap. I'm just an end-user, do not know how gimp uses this 'swap' :)
Maybe there is an env var, I just used the GUI interface to try and relocate the swap to a drive with more space.
I guess this is OK:
as for a default, or leave it like today, to choose based on some other window's specific logic.
Thanks.
Jehan
hopefully you see this Jehan :)
2018-09-18 12:15:07 UTC (3 months ago)
Hi!
Oh sorry. I thought this was some OS settings where you could configure where programs should cache their data by default.
Anyway I opened a bug report on our side: https://gitlab.gnome.org/GNOME/gimp/issues/2224
Jehan
the prefs.
I guess this is OK:
specific logic.
Thanks.
Jehan
-- stormy (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
Liam R E Quin
2018-09-18 16:37:57 UTC (3 months ago)
c:\Users\myuser\AppData\Local\Microsoft\Windows\INetCache\gegl- 0.4\12056-shared.swap
Can you move the two gegl folders to a different drive and put in shortcuts, until it's fixed? Maybe you did that already.
Liam (slave ankh on IRC)
Click here to have the slave beaten.
2018-09-18 19:40:51 UTC (3 months ago)
I guess this is OK:
Just to note that this would /not/ be a sensible default location for GIMP (or GEGL) to store its cache files. This is under a directory where Microsoft Windows stores /its/ own data. To be honest I'm not quite sure what INetCache is used for specifically. As far as I can make out from searching it's something to do with Internet Explorer's cache or perhaps running plugins in protected mode. Not sure why anything to do with GEGL would have ended up there though... is there a GIMP or GEGL browser plugin?
A more sensible default would be somewhere under, say: C:\Users\myuser\AppData\Local\GIMP\ i.e. a GIMP-specific directory under the local appdata directory. The local appdata directory is relocatable (as is the whole C:\Users directory), so the path used should be more like: %LOCALAPPDATA%\GIMP\
Where %LOCALAPPDATA% is an environment variable (set by Windows) containing the correct path to the current user's local appdata directory.
I believe there are also Windows API calls to retrieve the local appdata path. Looks like perhaps SHGetKnownFolderPath (since Windows Vista) or (deprecated) SHGetFolderPathA for compatibility with older versions:
If using %LOCALAPPDATA% or the API calls to get the local appdata path, it may not really be necessary to provide an option within GIMP to change those paths. Anyone wanting to move GIMP's appdata to a different disk should be able to just configure Windows to move the appdata directories, and as a bonus other applications (should) also store their data at the new location.
Note that there's also a "roaming" appdata path. That shouldn't be used for large amounts of data, particularly if temporary or disposable caches. On networks using roaming profiles, the roaming appdata directory is synchronised to a server during log-on/log-off, which gets slow if there's a lot of data there. It might be useful for configuration files though, since change made on one machine should then be carried over to other machines the user log on to (if roaming profiles are being used). Apologies for some vagueness; I've never actually had to be concerned with the details. Probably best look up authoritative info on Windows roaming profiles and correct usage of "local" vs "roaming" appdata directories if this is of concern.
Mark.
2018-09-19 17:59:24 UTC (3 months ago)
contact
Thanks for all these details. I'm not a developer, tried shortcut from:
to f:\temp\gegl0.4, but the short cut has a .lnk extension, removing it made the shortcut have a .4 extension :) in short, could not get it to work, and processing of any large file is just not possible b/c it locks up the PC pretty quickly as the swap is written to.. C:\...*some*place*... :)
if someone knows exact cmd, i can try it here, this is windows 10 and I'm new to gimp, etc, so don't assume much :)
2018-09-19 18:50:11 UTC (3 months ago)
I'd try to set the environment variable XDG_CACHE_HOME to e.g. f:\temp\gegl and see if this changes anything.
See https://superuser.com/questions/949560/how-do-i-set-system-environment-variables-in-windows-10 if you need advice on how to set these on Windows 10.
2018-09-19 20:42:03 UTC (3 months ago)
The detail I posted was mainly aimed at developers who might pick this up, in case they're not familiar with Windows conventions.
A shortcut probably won't work for this purpose. As you found, they have a .lnk extension, and the way they're handled by the OS doesn't do what's needed.
You might be able to achieve the right effect with an NTFS "directory junction". Windows doesn't provide a GUI for creating those, but it can be done from the command prompt. I believe you need to run the command prompt as administrator to do this.
1. Close GIMP.
2. Move "C:\Users\myuser\.cache\gegl-0.4" to "F:\temp\gegl0.4".
3. In Windows' Start menu, search for the "Command Prompt", right-click it and select "Run as administrator".
4. Enter the following command to create a directory junction: mklink /J "C:\Users\myuser\.cache\gegl-0.4" "F:\temp\gegl0.4"
5. Enter the following command to check: dir "C:\Users\myuser\.cache\"
In the output, you should see something like: DD/MM/YYYY HH:MM gegl-0.4 [F:\temp\gegl0.4]
Opening "C:\Users\myuser\.cache\gegl-0.4" in Windows Explorer will look like it's showing a directory at that path - the address bar will still show "C:\Users\myuser\.cache\gegl-0.4", not "F:\temp\gegl0.4". However, what appears to be the content of that directory is actually stored at "F:\temp\gegl0.4", and any files created in one location will also show up in the other. Any other application (such as GIMP) will also believe it's working with files under "C:\Users\myuser\.cache\gegl-0.4", when they're actually stored under "F:\temp\gegl0.4".
Hopefully that works. If not, the most likely difficulty is the "mklink" command. If you get any errors, be sure to mention the exact text of any messages.
Mark.
2018-09-19 20:45:44 UTC (3 months ago)
Try this before my suggestion - if it works, this is easier (and less confusing in future) than mucking around with directory junctions!
Mark.
2018-09-20 21:26:46 UTC (3 months ago)
contact
yes, by all means, thanks for the junction, not sure why it's so complex in Win..
anyways, tested: environment variable XDG_CACHE_HOME=f:\tmp\gimp , put it on USER level, without logoff or anything, just re-launch GIMP, and instantly these directories got created:
[code] Directory of F:\tmp\gimp
21-Sep-18 12:15 AM . 21-Sep-18 12:15 AM ..
21-Sep-18 12:15 AM fontconfig 21-Sep-18 12:14 AM gegl-0.4 21-Sep-18 12:15 AM thumbnails 0 File(s) 0 bytes [/code]
this looks very promising, will run heavy operations and u can assume if works if you don't hear again :) :)
