16 bit import - how to
16 bit import - how to Helmut Jarausch 23 Sep 12:44
  16 bit import - how to Alexandre Prokoudine 23 Sep 13:26
  16 bit import - how to Partha Bagchi 23 Sep 22:09
Helmut Jarausch
2015-09-23 12:44:38 UTC (over 8 years ago)
how can I import a raw (.rw2) file with 16bit color depth. I'm using the GIT-version of gimp. I have the ufraw plugin installed here but it seems to interpolate the colors to 8 bit only. The standalone ufraw has an option --out-depth but this doesn't seem to be used when I open a raw file in Gimp.
What am I missing?
Many thanks for a hint, Helmut
2015-09-23 13:26:16 UTC (over 8 years ago)
What am I missing?
Nothing ;) You just need to use the standalone version until the plugin code is adjusted to benefit from high bit depth support in dev version of GIMP.
Alex
Partha Bagchi
2015-09-23 22:09:05 UTC (over 8 years ago)
If you have compiled UFRaw correctly against GIMP 2.9 then click on the "Color Management" tab and change the output mode to 16.
What am I missing?
