Cannot click anything
Cannot click anything Madalrian 18 Mar 04:04
  Cannot click anything Pat David 18 Mar 22:18
   Cannot click anything akovia 18 Mar 22:43
  Cannot click anything Madalrian 19 Mar 04:51
  Cannot click anything poirotkr 03 Aug 10:49
2015-03-18 04:04:05 UTC (about 9 years ago)
I have almost completely given up on gimp just for this unbelievably frustrating problem, when I open gimp I can click a couple things then it just stops responding to clicks. I can do things with the keyboard and sometimes get the mouse to select things again but it stops after one or two clicks! I tried to access input devices to change my mouse to "Disabled" but i cant even click the option for it. I have looked up quite a few google searches trying to find an answer and have come across nothing that helps me, as the best description I can come up with is the mouse does not click. If anybody could help I would greatly appreciate it!
Pat David
2015-03-18 22:18:58 UTC (about 9 years ago)
What OS are you on?
If windows, do you also have an antivirus program running as well? If so, does pausing/turning off the antivirus stop the problem from happening? On Wed, Mar 18, 2015 at 4:41 PM Madalrian wrote:
appreciate it!
* http://www.gimpusers.com/system/attachments/189/ original/VIVALAREVOLUTION.jpg
-- Madalrian (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
akovia
2015-03-18 22:43:10 UTC (about 9 years ago)
This is a shot in the dark, but it kinda sounds like there may be a filter window open in the background. Probably not, but many a time I've opened up a dialog and then got distracted and that window went to the background under the main gimp window and it takes me a while to figure it out. Hope you sort it out though. Gimp has always been stable for me.
Cheers
On Wed, Mar 18, 2015, at 06:18 PM, Pat David wrote:
What OS are you on?
appreciate it!
akovia
2015-03-19 04:51:27 UTC (about 9 years ago)
Well it seems the problem is related to my Razer Deathadder, not sure if its the mouse itself or razer software but when i used a different mouse and restarted my pc it fixed the problem. thanks for the suggestions though!
2018-08-03 10:49:12 UTC (over 5 years ago)
I had the same problem as you had, but I solved it after I logged out of Skype. According to the below reference, you could also solve the problem after you stop running an Anti-virus program. I should thank who had posted this link, it's kind of a life savior for me. https://www.reddit.com/r/GIMP/comments/5rxa22/please_help_i_cant_click_on_ui/
