Getting a 32 bit install on a 64 bit system
Getting a 32 bit install on a 64 bit system Erik Lavender 12 Jan 00:47
  Getting a 32 bit install on a 64 bit system Joseph A Nagy Jr 12 Jan 01:52
   Getting a 32 bit install on a 64 bit system Erik Lavender 12 Jan 05:02
  Getting a 32 bit install on a 64 bit system Gunold Brunbauer 12 Jan 06:24
  Getting a 32 bit install on a 64 bit system rich 12 Jan 09:48
Erik Lavender
2015-01-12 00:47:37 UTC (over 9 years ago)
Basically I need to be able to setup a 32 bit install onto a thumb drive so I can use it on a computer with 32 bit windows (I don't have admin rights). So I need to get this installed from my 64 bit windows computer on which I do have admin rights.
Any ideas?
Joseph A Nagy Jr
2015-01-12 01:52:46 UTC (over 9 years ago)
Check out PortableApps, they have GIMP bundled for use on a thumb drive.
You can install any 32-bit app on a 64-bit machine without problems, so unsure of the issue here.
Any ideas?
Yours in Christ,
Joseph A Nagy Jr
"Whoever loves instruction loves knowledge, But he who hates correction
is stupid." -- Proverbs 12:1
Emails are not formal business letters, whatever businesses may want.
Original content CopyFree (F) under the OWL
http://copyfree.org/licenses/owl/license.txt
Erik Lavender
2015-01-12 05:02:02 UTC (over 9 years ago)
drive so
Did not notice a 32 bit one.
computer
The gimp installer detects and chooses which one to install.
Gunold Brunbauer
2015-01-12 06:24:44 UTC (over 9 years ago)
How about using the portable vesion of GIMP?
Am 12.01.2015 um 01:47 schrieb Erik Lavender:
Any ideas? _______________________________________________ gimp-user-list mailing list
rich
2015-01-12 09:48:23 UTC (over 9 years ago)
Erik Lavender gmail.com> writes:
so
List address: gimp-user-list gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list List archives: https://mail.gnome.org/archives/gimp-user-list
The correct way to go, for Gimp on a thumb drive, is use the portable version - look for portableapps.com You can use this on a regular machine as well.
Installing a regular Gimp to a thumb drive will leave a trail of a Gimp profiles across the machines it runs on.
The regular installer contains both 32 and 64 bit versions. To install a 32 bit Gimp in a 64 bit Windows OS append the switch -32 to the end of the installer.
ie. gimp-2.8.14-setup-1.exe -32
One peculiarity, Gimp is not installed to the 'Program Files (X86)' but to the 64 bit 'Program Files' unless you make an effort and use the customise option, bottom left of the Gimp setup dialog.
So in your case, point it at the thumbdrive and install there. Gimp is naturally portable, copy the whole '\GIMP 2' folder tree, to the 32 bit machine, make your own shortcut. No admin privilege might be a problem.
