Create From Clipboard -- Pasted Layer -- Problems Printing
ForumsFor GIMP users ► Create From Clipboard -- Pasted Layer -- Problems Printing
Sent: 2010-09-01 19:22:07 UTC (over 1 year ago)
Gimp 2.6.6 on Ubuntu 8.04 Linux. Minimum 2GB of memory. Used to editing (but
not printing) images to 200 MB.
I am running into some strangeness that I don't know is a an error in my
actions, a general workflow problem, or a bug (or feature) in Gimp.
Starting with a (color) JPEG image from a digital camera. Looks fine on screen,
but when I try to print it, the printer chokes (which is extremely unusual for
this printer, but does happen now and then; it is a big Kyocera b/w laser with
maximum memory and maximum hard drive) -- after several minutes of processing
still nothing coming out. OKAY that is NOT the problem -- I can understand that
the image may be too large and/or the color to b/w conversion on the printer is
not efficient on that printer.
So, I created a new image by doing the following.
Select All in original image.
Copy
File, Create, From Clipboard
Creates a new image that looks like the previous.
I change the size (scale) to something more suitable for printing.
AT THIS POINT I HAVE **NOT** SAVED THIS NEWLY CREATED IMAGE. THAT IS IMPORTANT.
When I HOVER OVER AND look in the bottom status bar of the window containing the
newly created image, it says "Pasted Layer" and gives a size in MB, about 20 MB.
I say to myself "Self, that does not look right". I do Flatten Image, I do
Merge Layers, etc. The "Pasted Layer" text remains, but the size keeps
increasing in roughly 20 MB jumps. When I look in the layer dialog, it only
shows one layer. However, when I click the eyeball the picture disappears and I
get a gray checkerboard, so there is something more present than just that one
layer.
(I _have_ double-clicked both on and off the image (I had to make the window
larger first to click off the image) to try to anchor the layer or finalize the
pasting or whatever you want to call it. However, if that did anything, it
increased the above stated MB size.)
When I try to print this (still NOT saved) image, I can't get it to print. I
even have trouble getting the print dialog to appear sometimes. Something is
strange.
So, to get a SaveAs dialog, I start to "Close" the image (I know, that is a
strange way to do it) and select Save, getting the SaveAs dialog. I save it to
.jpg and accept the current defaults. Thus it is now closed and has an actual
image name.
I reopen the image. Now when I HOVER OVER AND look in the bottom status bar of
the window containing the image, it now says "Background" and has a 3.9 MB size
(completely reasonable). Everything is normal. It prints perfectly fine and
quickly.
So, why do I have to save the image to a file...
- before I can print it?
- before the "Pasted Layer" text goes away (and becomes "Background")?
- before the size is stated more reasonably
Is this a problem with my (fairly elderly) printer vs Gimp's native
while-in-editing file format?
Am I doing something wrong?
It is no big deal to save and close the image to a file and then re-open it in
order to print. It is not going to ruin my day. But, it seems very strange to
have to do that (and has not been necessary in some other image editing programs
I have used), thus my query.
Jay
Gimp-user mailing list
Reply to this message
Sent: 2010-09-01 21:45:00 UTC (over 1 year ago)
> Copy
Hi Jay,
what gets displayed is the total amount of memory GIMP reserves for that image.
For various (good) reasons, this is usually much more memory than required to
hold a 'flattened down' version of that image.
Have a look at Image->Image Properties:
the first tab 'Properties' details a bit how the memory gets used. A good share
is required for the undo/redo functionality. That is the reason why shrinking
an image doesn't free much memory, if at all: the previous version is still kept
in memory in case you want to undo the shrinking.
> layer.
No, that's a fallacy: the checkerboard isn't part of the image. It gets shown so
you can identify transparent areas of your image. And if you hide all layers,
your image becomes fully transparent.
> image name.
> quickly.
you shouldn't have to. Something is going wrong here...
The statusbar shows the name of the active layer and "Pasted Layer" is just
the name of the newly pasted layer. When you store the file as JPEG, that name
gets lost because JPEG does not support layers. On re-opening the default name
'Background' gets chosen.
what is relevant for the amount of data that gets sent to the printer
is the number of pixels, not how much memory GIMP consumes for your image.
You already did rough estimes based on the pixel count and that is correct.
no
possibly. Are you shure you used *Image*->Scale instead of Layer->Scale?
That might explain the unexpected behaviour.
you are right, that should not be the normal mode of operation!
A hint to possibly track down the problem: saving as JPEG and re-opening effectively
flattens the image for you (and as a side-effect the memory required for undo/redo
gets freed, as you have observed).
regards,
peter
Sent: 2010-09-30 09:05:50 UTC (over 1 year ago)
Hi Jay,
you'll be pleased to hear that the next release of GIMP will enable you
to display the Megapixel count by configuring the status bar messsage.
The corresponding change has just been pushed to git master.
regards,
peter
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Cool glowing text Cool glowing text 40
  2. Creating 3D icons Creating 3D icons 35
  3. Create an amazing electricity effect on any object! Create an amazing electricity effect on any object! 6
  4. Create the Dragan effect Create the Dragan effect 2
Latest comments
But I just have 1 more prob (bear with me) I am really having troub... (2 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
I got it to work :) I had to close the image and restart it. I thin... (2 days ago in Create cool rifts with translucent lights!)
there was a second and 3rd release of 2.6.12. we included the lates... (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
750 Twitter followers
powered by bitfire it services
