Need a bit of help, 2 layer, need to edit
ForumsFor GIMP users ► Need a bit of help, 2 layer, need to edit
Sent: 2010-07-02 19:59:25 UTC (over 1 year ago)
Well, you'll recognize me :-) I've learned much, have copied my picture over
a background having 2 layers. The picture is semi-transparent, just what I
want. But the picture has a small part I need to either cut, clear, or somehow
get rid of. All I can manage to do is Free Select and draw around what I want
to cut but when I cut the image actually gets more bold and clear. What am I
missing? Thanks....
Greg A. (via www.gimpusers.com)
Gimp-user mailing list
Reply to this message
Sent: 2010-07-02 20:41:29 UTC (over 1 year ago)
missing? Thanks....
Sent: 2010-07-03 11:07:49 UTC (over 1 year ago)
> missing?  Thanks....
I'm not sure what you mean by "bold and clear". Usually "clear" is a
good thing, but you don't seem to like your "clear". :)
Anyway, try this method:
http://www.brankovukelic.com/post/526945497/effective-background-extraciton-gimp
Also, when using selection to erase parts of an image, you can control
the softness of the edge by using Select > Feather.
Branko Vukeli?
bg.branko@gmail.com
studio@brankovukelic.com
Check out my blog: http://www.brankovukelic.com/
Check out my portfolio: http://www.flickr.com/photos/foxbunny/
Registered Linux user #438078 (http://counter.li.org/)
I hang out on identi.ca: http://identi.ca/foxbunny
Gimp Brushmakers Guild
http://bit.ly/gbg-group
Sent: 2010-07-03 19:11:34 UTC (over 1 year ago)
Sounds to me like you are only applying the selection to one layer. Make
your selection, and perform your cut; then, in the layer dialog, select
successive layers without moving the selection, and cut the same part
out of each layer.
Alternatively, if the entire image is as you want it to be, and you have
no need for maintaining the separate layers, merge the layers together,
and then make your cut.
ns
Sent: 2010-07-04 00:17:54 UTC (over 1 year ago)
Neil, your suggestion made sense and worked perfectly. I actually had 5
layers, when I pasted the pic onto the background it was too light so I copied
again, added to the depth, so I ended up doing this 4 times and got just the
right look. So, I needed to cut 4 times, then used smudge to blend. Thanks
for the help guys.......
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Generate a stripe-like texture Generate a stripe-like texture 6
  3. Create a shocking sphere/ball Create a shocking sphere/ball 20
  4. Create futuristic looking tech pattern Create futuristic looking tech pattern 12
Latest comments
But I just have 1 more prob (bear with me) I am really having troub... (2 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
I got it to work :) I had to close the image and restart it. I thin... (2 days ago in Create cool rifts with translucent lights!)
there was a second and 3rd release of 2.6.12. we included the lates... (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
750 Twitter followers
powered by bitfire it services
