Fwd: Re: Need help: "correcting" exposures in time-lapse imagesets
ForumsFor GIMP users ► Fwd: Re: Need help: "correcting" exposures in time-lapse imagesets
Sent: 2010-02-08 05:17:08 UTC (about 2 years ago)
Hi, my son and I are doing a science project in which we're measuring dye
transport
in plant leaves over time. Using a Canon Powershot A40 and Canon's
RemoteCapture app to
snap images every 60 seconds.
Unfortunately, through RemoteCapture you can set film speed, but shutter
speed
remains in Auto mode. In order to digitally compare each image with the
initial
reference image (to determine the amount of dye absorbed), the exposures
need
to be the same each time.
Is there a way to compensate for exposure time in a relatively accurate way,
say,
see each image as if it were shot in 1/20 sec? I wish I could use the CHDK
package,
but the A40 doesn't seem to be supported.
kinata
kinata (via www.gimpusers.com)
Gimp-user mailing list
Reply to this message
Sent: 2010-02-08 20:29:45 UTC (about 2 years ago)
Quoting kinata :
> transport in plant leaves over time. Using a Canon Powershot A40 and
> Canon's RemoteCapture app to snap images every 60 seconds.
> speed remains in Auto mode. In order to digitally compare each image
> with the initial reference image (to determine the amount of dye
> absorbed), the exposures need to be the same each time.
Is flash mode available in remote capture? If so, perhaps one could be
used to obtain a consistent exposure (no AE, and the "shutter speed"
effectively is determined by the flash).
> say, see each image as if it were shot in 1/20 sec? I wish I could use
> the CHDK package, but the A40 doesn't seem to be supported.
Perhaps you could include a test pattern in the frame (ie, place a
picture of a test pattern next to the plant) and be able to match
exposure settings by adjusting the levels of the images such that the
two test patterns match (if this works, it could likely be automated).
Sent: 2010-02-09 09:49:16 UTC (about 2 years ago)
Saul, thank you, sir...replies follow.
Well, our brainstorm was to use a fluorescent dye,
without using a flash. The exposure times range
from 1 sec to 1/20 sec, ISO 200, f2.8. This
wouldn't represent a showstopper, as we're
concentrating on the area of each image that
contains pixels having that color of dye. So I
just need to iterate through the pixels and count
those having a certain threshold of a defined RGB
value to get the area of the image containing the
dye.
Now I reveal my true ignorance. I was thinking
that I could duplicate a layer containing a source
image, play with its opacity, and then merge
the layer back into the original source image to
arrive at a target "exposure". Might that work?
In a related issue posted elsewhere in this forum,
I'm wanting to isolate the dye part of the image:
-- convert the RGB triple for the dye color
(approximately a cyan) to HSB (HSV?)
colorspace,
-- rotate it to (say) green, and then
-- extract the green layer of the image.
This last is probably off-topic...just being
conversational.
Kinata
Sent: 2010-02-10 00:29:11 UTC (almost 2 years ago)
Sent: 2010-02-10 20:13:14 UTC (almost 2 years ago)
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Creating an abstract chaos explosion Creating an abstract chaos explosion 10
  3. Create a simple Grunge-Stamp! Create a simple Grunge-Stamp! 7
  4. Ashes to ashes, dust to dust. Dissolve text into particles Ashes to ashes, dust to dust. Dissolve text into particles 3
Latest comments
2.6.12 crashes on startup in windows xp. 2.6.11 works fine. (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Thank you! You really helped! The tutorial went great for me! Tha... (5 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
maybe you still selected a channel or so? explicitly click a layer ... (5 days ago in Create cool rifts with translucent lights!)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
View results
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
749 Twitter followers
powered by bitfire it services
