How to crop with defined aspect ratio ???
Forums ► For GIMP users ► How to crop with defined aspect ratio ???
bdfee97d1002031402o574e982dl9adcadc5e2f21cda@mail.gmail.com
- Dave 77459 (about 2 years ago)
helices
(about 2 years ago)
- Frank Gore (about 2 years ago)
- Akkana Peck (about 2 years ago)
Sent: 2010-02-03 22:52:59 UTC (about 2 years ago)
When I'm editing an image and I want to crop that image so it will print
8x10 or 5x8 or whatever, I'm challenged by adjusting the selection box
to exactly the right proportions.What am I missing?
Best Regards,
Mike
Gimp-user mailing list
Sent: 2010-02-03 23:01:25 UTC (about 2 years ago)
> What am I missing?I usually use the "Canvas Size" option for that, and then reposition
the picture within the scaled canvas before clicking "Ok". But it's a
bit tough to re-position the picture precisely because it looks so
small in the dialog.I'd love to hear how others do it. I wish there was an interactive
selection transform tool that I can use modifier keys with.--
Frank Gore
Project Manager
www.projectpontiac.com
Sent: 2010-02-03 23:17:06 UTC (about 2 years ago)
helices writes:
> to exactly the right proportions.The Crop tool's options includes a checkbox for Fixed: Aspect ratio
and a field where you can type in 8:10 or 5:8 or whatever you need....Akkana
Sent: 2010-02-03 23:21:46 UTC (about 2 years ago)
>> What am I missing?
>> Best Regards,
>> Mike
> Mike,
> When you select the Crop tool, there is a settings dialog? (I do it from
> the toolbox).
> On the settings dialog, there is a "Fixed" checkbox. Check that, then
> select "Aspect Ratio" from the drop down to the right of it.
> In the box below, enter in 8:10 or 10:8 or 5:8 or 8:5. If you get the
> wrong one (is it height:width or width:height, I can never remember), you
> can use the "paper sheets" next to the box to make the selection.
> Hope this helps.
> Dave
>I note that I replied to sender, instead of the list. Culpa mea.
Dave
