gimpusers.com logo
German version English version
Not logged in
Sign up! | Lost password?
Latest discussion
  1. gimp-docs | yesterday 10:55 PM
    a new user perspective
  2. gimp-developer | yesterday 08:04 PM
    scanner support should be File->Acquire
  3. gegl-developer | yesterday 06:24 PM
    babl docs
  4. gimp-docs | yesterday 12:46 PM
    GIMP Manual
  5. gimp-user | yesterday 09:42 AM
    Bug
External news
Poll
How good are you at programming?
OMG, that is nothing for me at all!
I've been coding a little bit but I'm not very fit at it
I'm pretty good at programming and would maybe be able to write a Plug-In for GIMP
I'm very good at programming and I would theoretically be able to hack for the GIMP core
See results
Stats
gimpusers.com RSS feed
GIMP Forums » For GIMP users
Web resolution question
Jump to message:
  1. message 4B60564A.2050507@ticnet.com not available
    1. Web resolution question — bigskypa@gmail.com, 27 Jan 2010 04:22 PM
      1. Web resolution question — Programmer In..., 27 Jan 2010 06:53 PM
  2. message 4B60C70A.50109@gmail.com not available
    1. Web resolution question — Paul Hartman, 28 Jan 2010 12:33 AM
      1. Web resolution question — Programmer In..., 28 Jan 2010 07:15 AM
  3. Web resolution question — bigskypa@gmail.com, 27 Jan 2010 03:57 PM
    1. Web resolution question — Deniz Dogan, 27 Jan 2010 04:07 PM
      1. Web resolution question — Akkana Peck, 27 Jan 2010 07:01 PM
        1. Web resolution question — Programmer In..., 27 Jan 2010 07:10 PM
    2. Web resolution question — Paul Hartman, 27 Jan 2010 11:43 PM
      1. Web resolution question — Programmer In..., 28 Jan 2010 07:14 AM
As a registered user, you can subscribe forum threads in order to get notified when replies are posted. Just log in at the right top of the page if you already have an account, otherwise you can register for free.
Permalink:4B605A18.1080507@gmail.com
Date:27 Jan 2010 04:22 PM
Subject:Web resolution question
On 01/27/2010 10:05 AM, Noel Stoutenburg wrote:
> bigskypa@gmail.com wrote:
>> Is there a typical or standard monitor resolution a web site should be
>> designed for?
> If I remember correctly, there are (or were) two standard resolutions,
> one on Apple based machines, and one on Windows based machines.
> However, are you sure that it is the resolution which is the cause of
> the variance you see, and not the size and aspect ratios of the
> various display devices upon which you are viewing the image?
> ns
I wouldn't know how to determine if it were. I figure (wrongly) that if
2 pictures are placed in a specific location when I make a web page then
they should appear in the same location and relationship on the web.
Gimp-user mailing list
↑Back to thread overview
Permalink:4B607D86.50905@joseph-a-nagy-jr.us
Date:27 Jan 2010 06:53 PM
On 1/27/2010 9:22 AM, bigskypa@gmail.com wrote:
<snip>
That's how it should work. If that's not the case, check your CSS and
HTML for issues between the browsers. Generally the only reason the
images should /appear/ to be in different locations is because someone
is viewing the site wider or narrower then what you are seeing. If you
check out http://www.joseph-a-nagy-jr.us on a variety of machines,
you'll see that the images are placed pretty much in fixed positions
across all monitors, resolutions and web browsers.
Yours In Christ,
PIT
Emails are not formal business letters, whatever businesses may want.
Permalink:58965d8a1001271533v733216c3j2642d5591...
Date:28 Jan 2010 12:33 AM
On Wed, Jan 27, 2010 at 5:06 PM, <bigskypa@gmail.com> wrote:
> The only problem is....I have no idea how to set the width of my web page.
> I need to know the exact html code I'm supposed to use.
Perhaps use the width or max-width CSS properties in the appropriate
place on your page. Which one you use might depend on the structure of
your document and the browser used by your audience (I don't think IE6
supports max-width).
Permalink:4B612B6C.90001@joseph-a-nagy-jr.us
Date:28 Jan 2010 07:15 AM
I don't generally set a max-width unless I'm going multi-column (and
that can get rather advanced very quickly).
Yours In Christ,
PIT
Permalink:4B60545F.9010405@gmail.com
Date:27 Jan 2010 03:57 PM
designed for?
The problem I'm having is that when I make a web page the pictures are
in a different position as viewed from various computers.
Any ideas?
Permalink:7b501d5c1001270707q71c38340p1b267ad68...
Date:27 Jan 2010 04:07 PM
2010/1/27 <bigskypa@gmail.com>:
> designed for?
I virtually always make the assumption that the user has at least
1024x768 and make my websites 960 pixels wide. Last time I checked
only 4 percent of Internet users today had a resolution lower than
1024x768.
I'm not sure what you mean (or how this relates to the monitor resolution).
Deniz Dogan
Permalink:20100127180150.GB2392@shallowsky.com
Date:27 Jan 2010 07:01 PM
> > designed for?
Deniz Dogan writes:
> 1024x768.
http://www.netmarketshare.com/report.aspx?qprid=17 makes it look
more like 5-6% (they don't give a "less than", you have add up the
numbers for various specific resolutions).
But http://browsersize.googlelabs.com/ seems to be saying that more
like 30% of Google visitors have screens narrower than 1024.
"bigskypa" is probably assuming that everybody runs their browser
in fullscreen mode, so that it takes up the full monitor resolution.
Really, a better measure is how big people's actual browser windows are.
But a web page needs to be able to adjust to different browser sizes.
If your layout changes in unpredictable ways because you resized your
browser window, you need to fix your HTML layout.
That's one reason why GIMP isn't a good web design tool, though it's
great for making individual graphics to use as part of a web page.
Perhaps try an HTML forum to figure out where your HTML is going wrong?
...Akkana
Permalink:4B6081AE.6030508@joseph-a-nagy-jr.us
Date:27 Jan 2010 07:10 PM
On 1/27/2010 12:01 PM, Akkana Peck wrote:
<snip>
> ...Akkana
I'd also be willing to help, off-list, of course. (:
Yours In Christ,
PIT
Permalink:58965d8a1001271443v6f0f6241w5cad564c6...
Date:27 Jan 2010 11:43 PM
> designed for?
> Any ideas?
There is no standard. Monitor resolution also does not give you any
clue about DPI settings, user font size, window size, zoom level, etc.
There a million philosophies about web design and the only answer is
for you to do what you think is best for your site...
At home I have 2048x1152 monitor on primary computer, 1200x1600 on
secondary (yes, portrait orientation), my phone has 800x480
(landscape), my wife's phone has 240x320 (portrait), my grandpa is
using 800x600 on a 19inch monitor... you can imagine websites look
very different depending on which computer I use.
You can use something like Google Analytics to see what your customers
are using (assuming they have Javascript enabled...).
Permalink:4B612B2F.8070307@joseph-a-nagy-jr.us
Date:28 Jan 2010 07:14 AM
On 1/27/2010 4:43 PM, Paul Hartman wrote:
<snip>
Even if you only have Read Only access to your log files, you can use
AWSTATs as well, although I'm not sure if it can determine resolution it
gives a good idea of browser and os.
Yours In Christ,
PIT
Adobe® Photoshop® is a registered trademark of Adobe Systems, Inc. Linux is a trademark of Linus Torvalds. Ubuntu and Canonical are registered trademarks of Canonical Ltd. | Clock times are shown as CET / CEST | Imprint / Privacy policy | powered by bitfire it services | sponsored by Hirners Hotel Guide
