batches for web
Forums ► For GIMP users ► batches for web
20090703044059.GC22586@shallowsky.com
alec
(over 2 years ago)
- Bob Long (over 2 years ago)
- Michael Schumacher (over 2 years ago)
Patrick Horgan
(over 2 years ago)
- David Gowers (over 2 years ago)
alec
(over 2 years ago)
alec
(over 2 years ago)
(over 2 years ago)
- Jay Smith (over 2 years ago)
(over 2 years ago)
Sent: 2009-07-02 21:43:26 UTC (over 2 years ago)
batches for web
Howdy...
I finally installed David's Batch Processor (after months of trying to
figure out how to do batches) but I'm surprised that I don't see an
option for changing resolution. I'm simply trying to prepare
images(lots of them) for the web. Did I miss something in Daves
Batches? Or maybe someone has a link to something else that would work
for me? Thanks!
-Alec_______________________________________________
Gimp-user mailing list
Sent: 2009-07-02 22:06:45 UTC (over 2 years ago)
batches for web
> for me? Thanks!Resolution (as in dots-per-inch) is irrelevant for images used on
web-pages. The only thing that counts is the number of pixels.Sven
Sent: 2009-07-02 22:38:53 UTC (over 2 years ago)
batches for web
On 07/02/2009 04:06 PM, Sven Neumann wrote:
> Hi,
>> for me? Thanks!
> SvenBut... resolution is important for print output ... which is something I
am interested in.So I think Alec's question still stands.
Jay
Sent: 2009-07-07 06:27:23 UTC (over 2 years ago)
batches for web
Hi...
Akkana Peck wrote:
> Does Resize not do what you want? (I don't have DBP installed
> right now, but I thought it could scale images and looking
> at the web page I would guess Resize is what does that.)
Do you have a link to that plugin? I've searched quite a bit and David's
Batch processor has seemed the best so far, but I'm still(after a couple
years now) new to GIMP.
> ...Akkana
Sven Neumann wrote:
> Hi,
>> for me? Thanks!
Huh, I thought that lower resolution would make the file size smaller so
web images would load faster. No?Thanks-
Alec>>
Sent: 2009-07-07 07:41:08 UTC (over 2 years ago)
batches for web
alec wrote:
> Akkana Peck wrote:
[..]>> Resolution (as in dots-per-inch) is irrelevant for images used on
> web images would load faster. No?Depends what you are *really* referring to.
See http://www.scantips.com/basics01.html--
Bob Long
Sent: 2009-07-07 13:47:05 UTC (over 2 years ago)
batches for web
> Von: alec
> web images would load faster. No?Absolute resolution (aka 'image size'): yes
Relative resolution (aka 'pixels per inch'): no
See also "72 dpi myth", e.g. at http://www.scantips.com/no72dpi.html
HTH,
Michael--
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
Sent: 2009-07-08 01:15:55 UTC (over 2 years ago)
batches for web
Sent: 2009-07-08 03:19:41 UTC (over 2 years ago)
batches for web
On Wed, Jul 8, 2009 at 8:45 AM, Patrick Horgan wrote:
> The truth is that Gimp displays to you using your screen resolution, so if
> you originally created an image at 72dpi and 216x216 pixels and another
> image at 4800dpi and 216x216 pixels, Gimp will display them the same.
Sort of true, see below..> While
> they look the same, if you look at image properties with or
> set the disply units to inches in the bottom border and move around the
> image, you can see the difference. One is reported as 3" across and the
> other as .045" across. The resolution is used by Gimp to translate to
> inches and inch derived units for you.
> If you go into image/resize, and only change the dpi, Gimp will report to
> you that the image is a different size in inches, but the pixels are not in
> any way changed.
> Various image file types like jpg and png store resolution and Gimp does
> store that for you. Devices are supposed to scale the images so that on
> their display resolution they will appear the same size as in the images
> native resolution. Some devices/software actually do this.Like GIMP (toggle View->Dot for Dot off). When Dot for Dot is off,
GIMP displays the image at a scale matching the comparitive
resolutions of the screen and the image.> If you print
> something and it comes out the wrong size, some times you can open it in
> Gimp, change the resolution and resave. The only change will be in the
> stored resolution, the file's image data is completely unchanged, yet it
> will now print a different size!_______________________________________________
