Problem loading BMP; invalid BMP or bug in GIMP?
ForumsFor GIMP users ► Problem loading BMP; invalid BMP or bug in GIMP?
Sent: 2008-12-29 09:56:38 UTC (about 3 years ago)
I have some BMP-files that GIMP doesn't load correctly; GIMP shows
almost the whole image as transparent instead of the real image data.
Only a small region is visible, and even that with partial transparency.
The image doesn't contain any transparency though (I don't even think
BMP supports transparency).
Other image editors and viewers such as Irfanview and Paint.NET open the
image correctly.
I'm using GIMP 2.6.2 on Windows XP.
If you want to see the image, get it at
http://rschroev.fastmail.fm/radar-20081222T090636-00.bmp (5 MB) or
http://rschroev.fastmail.fm/radar-20081222T090636-00.zip (854 kB).
Should I report this as a bug? Or is the BMP maybe written in an invalid
format?
The saddest aspect of life right now is that science gathers knowledge
faster than society gathers wisdom.
-- Isaac Asimov
Roel Schroeven
Gimp-user mailing list
Reply to this message
Sent: 2008-12-29 11:50:04 UTC (about 3 years ago)
Roel Schroeven wrote:
> Hi,
> image correctly.
> format?
I can't help you :( I can only confirm what you are saying:
On Linux (Gentoo) - identify:
identify "radar-20081222T090636-00.bmp" (9575)
radar-20081222T090636-00.bmp BMP 1024x1280 1024x1280+0+0 8-bit
DirectClass 5mb
In gqview and cinepaint the image looks normal, so it is when imported
in Inkscape too.
In Gimp both 2.4 and 2.6.0 the image looks like you are describing -
transparent.
Greetings,
Peter
Sent: 2008-12-29 12:01:56 UTC (about 3 years ago)
> Hi,
> image correctly.
> format?
Hi
If other editors are able to open the file it is not corrupt. (Maybe it
is but the other loaders are then at least able to adjust for this.)
Feel free to file a bug report and attach the BMP.
- Martin
Sent: 2008-12-29 12:14:35 UTC (about 3 years ago)
> image correctly.
I am not so sure about that. The image opened in GIMP has all the
information and an alpha channel. If you change the alpha channel to be
all opaque, then you will see the image as shown by other viewers you
tried. So I would rather assume that the other viewers don't support
masks in BMP files and just ignore that extra information. As long as
that is not sorted out, you should not file this as a bug report against
GIMP. It is quite likely that the bug is elsewhere.
Sent: 2008-12-29 12:36:40 UTC (about 3 years ago)
Sven Neumann wrote:
> Hi,
>> image correctly.
> Sven
Sven is right. I just did:
"Add Layer Mask" -> "Transfer layer's alpha channel", check "Invert
Mask", then file -> open as layers -> open the original image, flatten
and the image is O.K.
So it is not a bug in GIMP, but maybe in the way the image was saved
with this mask.
Peter
Sent: 2008-12-29 12:42:34 UTC (about 3 years ago)
> with this mask.
One could argue though that the BMP loader in GIMP should use a layer
mask to represent the mask in the BMP file instead of using an alpha
channel for this. You would probably have discovered this more easily
then and it appears to be a better way to represent the BMP image
structure. So I think we should accept a patch that changed the BMP file
plug-in in this way.
Sent: 2008-12-29 14:55:11 UTC (about 3 years ago)
Sven Neumann schreef:
> Hi,
>> image correctly.
The image is a screenshot that I make using this simple Win32/VCL code:
// Graphics::TBitmap is a Borland VCL wrapper around a Windows bitmap
void CaptureFromDC(HDC hDcSource, TRect Rect, Graphics::TBitmap *Bitmap)
Bitmap->Width = Rect.Width();
Bitmap->Height = Rect.Height();
Bitmap->HandleType = bmDIB;
if (!BitBlt(Bitmap->Canvas->Handle,
0, 0,
Rect.Width(), Rect.Height(),
hDcSource,
Rect.left, Rect.top,
SRCCOPY))
throw ECaptureError();
I can easily convert the bitmap to 24 bits, and then the image looks
good in GIMP, which is to be expected since it doesn't contain any alpha
information anymore. And it has the added benefit that the image files
are smaller.
Either way it's no big deal to me. I only wonder exactly where the alpha
values come from, but I guess that's more a question for a win32
programming mailing list.
-- Isaac Asimov
Roel Schroeven
Sent: 2008-12-29 15:58:24 UTC (about 3 years ago)
Sven Neumann wrote:
> Hi,
>> with this mask.
Apparently Sven's answer didn't reach the list, so here it is:
> Sven
Roel, I don't understand your technique of creating this screenshot, but
it looks like the BMP file has a mask in it. This is the source of the
transparency, because the file-bmp plug-in transforms this into
transparency. Unfortunately I can't understand exactly how to change the
file-bmp plug-in to implement that what Sven is suggesting because at
this time I know just a little python, but not C.
Peter
Sent: 2008-12-29 16:14:18 UTC (about 3 years ago)
That doesn't seem to work for me. I get an image that is almost
completely white. No big deal though: I just use Irfanview to read and
save it, which removes the alpha channel.
> with this mask.
I suppose so. I'll just save the images with 24 bpp instead of 32 bpp;
that way the image doesn't include an alpha channel.
-- Isaac Asimov
Roel Schroeven
Sent: 2008-12-29 16:16:22 UTC (about 3 years ago)
> transparency.
Yes, I understand that now.
> Unfortunately I can't understand exactly how to change the file-bmp
> plug-in to implement that what Sven is suggesting because at this
I know C but not much about GIMP's internals or the BMP image structure.
I might try to create a patch if I find some time to study those.
-- Isaac Asimov
Roel Schroeven
Sent: 2008-12-30 19:30:48 UTC (about 3 years ago)
> alpha information anymore. And it has the added benefit that the image
> files are smaller.
> alpha values come from,
They could come from anywhere.
Historically, neither the BMP format nor the internal Windows structures
that it maps to formally define an alpha channel. The BITMAPINFOHEADER
biBitCount field can be set to 32, but the Windows SDK documentation
says that in that case "the high byte...is not used." In the RGBQUAD
structure used to hold 32-bpp pixels, the fourth field is "rgbReserved,"
not "rgbAlpha," and the description is "Reserved; must be zero."
The rationale for 32-bpp BMPs with an unused byte per pixel was that it
kept pixels longword-aligned, which in long-ago times sped up image
processing.
Naturally, BMP has been extended so that alpha is sometimes stored in
that fourth byte, and sometimes this is done out of ignorance, because
people *assume* that a 32-bpp format supports alpha. But alpha in BMP
is by no means widely supported. There's no easy way to tell whether a
given 32-bpp BMP contains a real alpha channel. And Windows itself
doesn't directly support BMP with alpha.
Since most 32-bpp BMPs *don't* contain alpha, and in those images the
fourth byte is 0, most image readers ignore the fourth byte.
A useful extension to any image loader/saver would be a preference
setting with options like
* Assume 32-bpp BMPs have alpha
* Assume that they don't
* Ask me each time
- Ernie http://home.comcast.net/~erniew
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Creating an abstract chaos explosion Creating an abstract chaos explosion 10
  3. Create a simple Grunge-Stamp! Create a simple Grunge-Stamp! 7
  4. Ashes to ashes, dust to dust. Dissolve text into particles Ashes to ashes, dust to dust. Dissolve text into particles 3
Latest comments
2.6.12 crashes on startup in windows xp. 2.6.11 works fine. (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Thank you! You really helped! The tutorial went great for me! Tha... (5 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
maybe you still selected a channel or so? explicitly click a layer ... (5 days ago in Create cool rifts with translucent lights!)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
View results
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
749 Twitter followers
powered by bitfire it services
