how to build the help files from existing html ?
Forums ► GIMP documentation (read-only) ► how to build the help files from existing html ?
Cristian Secară
(4 months ago)
- Ulf-D. Ehlert (4 months ago)
Sent: 2012-01-31 17:06:44 UTC (4 months ago)
În data de Tue, 4 Aug 2009 20:30:48 +0200, Ulf-D. Ehlert a scris:
> The script we used when migrating to gettext-based documentation
> failed to extract, save, and reuse the glossary translations, I did
> never find out why. :-(From this older post I understand that the documentation is now in
gettext format (?) and that there is/was an utility to convert an
existing html text to gettext (?).Where can I find more details about this ?
There is someone who has translated the 2.6.x in Romanian as html
http://gimp.e3.ro/
(less the translated snapshots)He is now ready to update the text to suit 2.8.
What is the way he must go on ?Cristi
Cristian Secară
http://www.secarica.ro
Sent: 2012-01-31 17:51:08 UTC (4 months ago)
> existing html text to gettext (?).No. If I remember correctly, that script converted our multi-language
XML-files to several single-language XML-files of exactly the same
structure, e.g.old-doc.xml
etc.was converted to
en/new-doc.xml xx/new-doc.xml yy/new-doc.xml etc.
and then these XML-files were converted to po-files.
> http://gimp.e3.ro/
> What is the way he must go on ?Hmm, no idea right now... :-(
Ulf
Nichts macht deutlicher, dass die Religion von Menschen erschaffen
wurde, als das kranke Hirn, das sich die Hölle ausdachte, ...
-- Christopher Hitchens, "Der Herr ist kein Hirte"
819 @ Twitter
