Help Documentation - Gimp Scripting
Forums ► GIMP documentation (read-only) ► Help Documentation - Gimp Scripting
Stephen Kiel
(4 months ago)
Kolbjørn Stuestøl
(4 months ago)
Vitaly Lomov
(4 months ago)
Julien Hardelin
(4 months ago)
Alexandre Prokoudine
(4 months ago)
- Julien Hardelin (4 months ago)
(4 months ago)
Julien Hardelin
(4 months ago)
Vitaly Lomov
(4 months ago)
Kolbjørn Stuestøl
(4 months ago)
Sent: 2012-01-23 15:51:05 UTC (4 months ago)
I really appreciate the help documentation and the Gimp application in
general. I thought it would be good for me to try to give something back.
I focused on something that I struggled with, scripting with script-fu. I
found that a lot of the help didn't quite get me to where I wanted to go.
I thought about how I would improve the documentation to tell the story a
better, and I felt that for me it was easier to just start with a clean
sheet and lay it out.I would like to offer my take on a Gimp Scripting tutorial for use as part
of the Gimp documentation. You may use all of, part of, or none of it as
you see fit. It is my hope that this can benefit others, but I have no
other forum or place to post this tutorial. You or we can make what ever
modifications to the code examples or text to make the explanation clearer
or add any copyright required for release with Gimp.The tutorial is under my spideroak share at:
https://spideroak.com/browse/share/Stephen_Kiel_Pictures/tutorial
The "RoomKey" is tutorialThe files in this share are:
GimpScriptingTutorial.docx
GimpScriptingTutorial.pdf
Images
scripts
Thumbs.db./Images:
Thumbs.db
workflow-perspective-adjust.JPG./scripts:
configscripts
README.txt
roys-lum-separate.scm
roys-max-local-contrast.scm
script-fu-chroma-mask.scm
script-fu-combo-baselayers.scm
script-fu-combo-contrast-separate.scm
script-fu-combo-prep.scm
script-fu-delete-dummylayer.scm
script-fu-display-asigned-parasites.scm
script-fu-examples.scm
script-fu-flowzilla.scm
script-fu-get-named-drawable.scm
script-fu-grid.scm
script-fu-grow-canvas.scm
script-fu-jpg-to-xcf.scm
script-fu-list-index-from-name.scm
script-fu-make-two-layers.scm
script-fu-mark-autoupdate.scm
script-fu-mark-noautoupdate.scm
script-fu-para-note.scm
script-fu-para-tat-layer.scm
script-fu-scale-image.scm
script-fu-tat-origlayer.scm
script-fu-update-image.scm
script-fu-wrap-local-contrast.scm
script-fu-wrap-lum-separate.scm
script-fu-xcf-to-jpg.scm./scripts/configscripts:
sf-config-layerdef.scm
sf-config-paranote.scmIf you choose not to use any of the tutorial that I wrote, let me know at
your convenience so I can take down the share.Thanks for putting together a great application.
Stephen Kiel
Stephen Kiel
26602 Strafford
Mission Viejo, CA 92692
Home (949) 367-2915 Mobile (949) 702-1993
Google Voice SMS (949) 354-2828
snick.kiel@gmail.com
http://stephenkiel.blogspot.com/
Skype: stephen.kiel
Sent: 2012-01-24 11:08:08 UTC (4 months ago)
I am impressed. Although I only have read the tutorials without trying
to write the scripts. The tutorials are well written. The examples will
be of good use to many GIMP users I think.I think this tutorial should be accessible in some way to the users
taking interests in using scrips. Perhaps this tutorial is too long to
be incorporated as a part of the documentation. May be a cropped version
with links to full version would be a solution?
I assume that the script functions will be available and unchanged in
the v 2.8.
Somebody take the challenge and writes the tutorials in "GIMP
documentation style"?
KolbjoernDen 23.01.2012 16:51, skreiv Stephen Kiel:
> Hello,
> back. I focused on something that I struggled with, scripting with
> script-fu. I found that a lot of the help didn't quite get me to where
> I wanted to go. I thought about how I would improve the documentation
> to tell the story a better, and I felt that for me it was easier to
> just start with a clean sheet and lay it out.
> part of the Gimp documentation. You may use all of, part of, or none
> of it as you see fit. It is my hope that this can benefit others, but
> I have no other forum or place to post this tutorial. You or we can
> make what ever modifications to the code examples or text to make the
> explanation clearer or add any copyright required for release with Gimp.
Sent: 2012-01-24 13:41:01 UTC (4 months ago)
I liked the PDF version, nice structure. Assuming the functions are the
same, etc., why can't be incorporate it? I don't understand the length
argument. It always comes down to " we are just a manual and a reference,
not a book". But then, the script-fu chapter should be two lines: a link to
Scheme language reference and "read function comments to learn what they
do". I like that the tutorial addresses the object model of GIMP -
image/drawable, etc. That's what we need. As to who will incorporate, I
don't know.2012/1/24 Kolbjørn Stuestøl
> I am impressed. Although I only have read the tutorials without trying to
> write the scripts. The tutorials are well written. The examples will be of
> I think this tutorial should be accessible in some way to the users taking
> interests in using scrips. Perhaps this tutorial is too long to be
> incorporated as a part of the documentation. May be a cropped version with
> I assume that the script functions will be available and unchanged in the
> v 2.8.
> Kolbjoern
> Hello,
>> general. I thought it would be good for me to try to give something back. I
>> found that a lot of the help didn't quite get me to where I wanted to go. I
>> part of the Gimp documentation. You may use all of, part of, or none of it
>> as you see fit. It is my hope that this can benefit others, but I have no
>> https://spideroak.com/browse/**share/Stephen_Kiel_Pictures/**tutorial
> ______________________________**_________________
> gimp-docs-list mailing list
> gimp-docs-list@gnome.org
> http://mail.gnome.org/mailman/**listinfo/gimp-docs-list
Sent: 2012-01-24 20:49:01 UTC (4 months ago)
> the same, etc., why can't be incorporate it? I don't understand the
> length argument. It always comes down to " we are just a manual and a
> reference, not a book". But then, the script-fu chapter should be two
> lines: a link to Scheme language reference and "read function comments
> to learn what they do". I like that the tutorial addresses the object
> model of GIMP - image/drawable, etc. That's what we need. As to who
> will incorporate, I don't know.
That's the main problem: who will translate this text to xml? At
gimp.org, there are two tutorials about scripts. They were created in
2003. This tutorial could be added there. And we add a link to it in the
doc.Julien
Sent: 2012-01-25 13:41:20 UTC (4 months ago)
Is that really a problem? I can do it.
http://libregraphicsworld.org
Sent: 2012-01-25 18:02:04 UTC (4 months ago)
> Is that really a problem? I can do it.Good!
Will this tutorial be included at the place of the present script-fu
tutorial? It is big and I see it as an annex.Julien Hardelin
819 @ Twitter
