GIMP's manual in arabic
ForumsGIMP documentation (read-only) ► GIMP's manual in arabic
Sent: 2010-07-19 10:28:37 UTC (over 1 year ago)
On Mon, Jul 19, 2010 at 08:44:09AM +0100, Alexander Zack Malcolmson wrote:
> Sorry forgot to ask about the gimp-docs@lists.XCF.Berkeley.EDU mailing list:
> Is it better if I copy in (cc) all my email concerning this issue to the mailing list?
I think in general this discussion should happen on the mailing list :)
Cheers
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
Sent: 2010-07-21 00:42:52 UTC (over 1 year ago)
Hi Alexander,
On Tue, Jul 20, 2010 at 09:46:14AM +0100, Alexander Zack Malcolmson wrote:
> All that is required is to add the following attributes to the main html tag during the build process:
> xml:lang="ar" lang="ar" dir="rtl"
> which basically provoke arabic language support in html rendering engines.
Because the HTML is transformed by using the XSL stylesheets, we
probably have to have a look at DocBook to set a parameter/option which
finally results in an HTML file with this information.
I haven't had a look at DocBook so far, but I bet the change is easy.
Cheers
Roman Joost
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Generate a stripe-like texture Generate a stripe-like texture 6
  3. Create a shocking sphere/ball Create a shocking sphere/ball 20
  4. Create futuristic looking tech pattern Create futuristic looking tech pattern 12
Latest comments
But I just have 1 more prob (bear with me) I am really having troub... (2 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
I got it to work :) I had to close the image and restart it. I thin... (2 days ago in Create cool rifts with translucent lights!)
there was a second and 3rd release of 2.6.12. we included the lates... (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
750 Twitter followers
powered by bitfire it services
