push/pull problems
Forums ► GIMP documentation (read-only) ► push/pull problems
4BA7A7F1.7060701@stuestoel.no
Kolbjørn Stuestøl
(almost 2 years ago)
Claude Paroz
Kolbjørn Stuestøl
Claude Paroz
Kolbjørn Stuestøl
Kolbjørn Stuestøl
Roman Joost
- Kolbjørn Stuestøl (almost 2 years ago)
Roman Joost
Kolbjørn Stuestøl
Kolbjørn Stuestøl
Claude Paroz
Kolbjørn Stuestøl
Claude Paroz
Kolbjørn Stuestøl
- 4BA7585C.7090407@stuestoel.no
- 598e9211003220459r45697819xe0003056c5cc8387@mail.gmail.com
- 4BA762CB.5080109@stuestoel.no
- 598e9211003220626m2ced0479j978673e73ef0e034@mail.gmail.com
Kolbjørn Stuestøl
- Roman Joost (almost 2 years ago)
Sent: 2010-03-19 12:03:00 UTC (almost 2 years ago)
push/pull problems
When trying to pull or push files from/to server I get the following
message:$ git push
ssh: connect to host stuestoel.no port 22: Connection timed out
fatal: The remote end hung up unexpectedlyAccording to what said in live.gnome.org/TranslationProject/GitHowTo my
account is accepted. I.e. the command ssh -v MYUSERNAME@git.gnome.org
returns what expected.I do not know what "host stuestoel.no" is. (Assuming GNOME has nothing
to do on my home site www.stuestoel.no).
I think I have given a wrong command somewhere, but what do I have to do
to correct it?My config file is
$ git config -l
user.name=Kolbjørn Stuestøl
user.email=kolbjoern@src.gnome.org
color.ui=auto
remote.origin.url=ssh://kolbjoern@stuestoel.no/git/gimp-help-2
core.repositoryformatversion=0
core.filemode=true
core.bare=false
core.logallrefupdates=true
core.ignorecase=true
remote.origin.fetch=+refs/heads/*:refs/remotes/origin/*
remote.origin.url=ssh://kolbjoern@git.gnome.org/git/gimp-help-2
branch.master.remote=origin
branch.master.merge=refs/heads/masterBTW: Why is the remote.origin.url defined twice?
Kolbjoern_______________________________________________
Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
Sent: 2010-03-23 13:19:41 UTC (almost 2 years ago)
push/pull problems
Invalid .doap fil?
Finally I get through, resulting in another problem ;-)
"git push" results in this return message:$ git push
Counting objects: 848, done.
Compressing objects: 100% (435/435), done.
Writing objects: 100% (486/486), 219.00 KiB | 13 KiB/s, done.
Total 486 (delta 255), reused 4 (delta 0)
ERROR: gimp-help-2.doap is not valid:
Invalid foaf:mbox property should be a mailto: URLPlease see:
http://live.gnome.org/MaintainersCorner#maintainers
To ssh://kolbjoern@git.gnome.org/git/gimp-help-2
! [remote rejected] master -> master (pre-receive hook declined)
error: failed to push some refs to
'ssh://kolbjoern@git.gnome.org/git/gimp-help-2'I have not changed the .doap file. Compared the gimp-help-2.doap to the
one on the web site mentioned and found of course no difference in the
setup. I do not believe the error is in the .doap file as others
obviously are using it without problem and I have not changed it.
The steps before the "git push":*** Validating XML (nn) ...
nn: no errors.$ git add .
$ git commit -m "Updated Norwegian translation"
[master 075746b] Updated Norwegian translation
1 files changed, 1 insertions(+), 8 deletions(-)Checked the http://git.gnome.org/browse/gimp-help-2/ in case of newer
updates. None.
Some help?
Sent: 2010-03-23 21:52:02 UTC (almost 2 years ago)
push/pull problems
Le mardi 23 mars 2010 à 13:19 +0100, Kolbjørn Stuestøl a écrit :
> Invalid .doap fil?
> $ git push
> Please see:
> nn: no errors.
> $ git add .Never, never do that. You might have untracked files (generated by some
operation) or files automatically changed for any reason (e.g. you host
files on a FAT32 partition). 'git status' will tell you about that.
Then 'git add' selected files that you purposely changed.HTH,
Claude
www.2xlibre.net_______________________________________________
Sent: 2010-03-23 22:44:41 UTC (almost 2 years ago)
push/pull problems
Claude Paroz skreiv:
>> Invalid .doap fil?
>> $ git push
>> Please see:
>> nn: no errors.
>> $ git add .
Never do what? Change the .doap file or whatever?
> HTH,
> Claude
I have run the "git status" but omitted it in the listing above because
I do not understand what it tells me. I obviously have to study the git
sites a bit more. The last thing I did before "git push" was as listed.
("git add ." --- "git status" --- "git commit").
Sent: 2010-03-23 23:41:47 UTC (almost 2 years ago)
push/pull problems
> >> Invalid .doap fil?
> >> $ git push
> >> Please see:
> >> nn: no errors.
> >> $ git add .
> Never do what? Change the .doap file or whatever?Never do "git add .". Basically, this command tell gits that all
modified/new files in the checkout should be added in the next commit.
In most of cases, this will add too much unwanted stuff (like the .doap
file you never intended to modify).It is better to add selectively the files you know you want to be
committed. (e.g. git add po/sv/gimp.po)Claude
Sent: 2010-03-24 02:24:38 UTC (almost 2 years ago)
push/pull problems
Hi Kolbjørn,
> message:
> My config file is
> $ git config -l
> color.ui=auto
remove that ^> [...]
> Kolbjoern
You may have set one globally by accident?Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org_______________________________________________
Sent: 2010-03-24 12:30:03 UTC (almost 2 years ago)
push/pull problems
> Claude
Thank you Claude and Roman
I'll work further on these tips. Hoping to succeed some day.
Sent: 2010-03-24 18:23:09 UTC (almost 2 years ago)
push/pull problems
At last I got through.
Thank you Claude, Roman, and Julien.(private mails) and to Ulf for
changing the gimp-help-2.doap file.
As I am the only Norwegian translator, I have time to correct any
mistakes or mash ups :-)I do not know what went wrong at the first place and how I corrected it.
I just removed all new git files from my folders and started from
scratch again.Kolbjoern
Sent: 2010-03-26 10:16:55 UTC (almost 2 years ago)
push/pull problems
> scratch again.
While you're saying that, I'll sometimes use:git clean -x -d -f
to remove all files which were generated during the setup or install
process to start from scratch. Keep in mind before executing that this
will also wipe all unknown files to git from the directory, including
your working version you haven't committed ;)Cheers,
Roman Joost
Sent: 2010-03-26 15:56:48 UTC (almost 2 years ago)
push/pull problems
Roman Joost skreiv:
> git clean -x -d -f
> Cheers,
Oh, should have known this command before :-) Much better and faster
than my handwork. I save the tip for future use. It will come ;-).
Another reason for reading the git handbook more carefully.
